Starter/Alternator issue?
Took car out today, voltage started out normal, drove around for about a half an hour, parked, got out, did some shopping, came back started the car, I get low voltage again. I get home, let car sit for awhile, start it, low voltage. Car has a Mechman alternator, figured I would swap it out with my OEM one. Put old one in, start it up, low voltage. I shut car, start again and voltage was over 14. I put voltmeter at alternator, was around 14.5, voltage at battery and fuse box was 13.5. Put car on ramps, check wires at starter, they were tight, but when I pushed them I could see the terminal move ever so slightly. Would this mean solenoid is on its way out? Starter is 2 years old, car has headers.
What do you think?
Solenoid failures, ESPECIALLY w/ headers if both headers and starter aren't heat wrapped, aren't unusual.
Seems much more common w/ car's in 'hot' climate, so where do you live?
Should be no movement on solenoid posts and if there is it may indicate bakelite cracked.
If solenoid checks out, might be alternator's in the process of failing, ergo, intermittent performance/behavior.
Those 2 items have to be thoroughly checked and ruled out as a cause.
So new starter solenoid to replace on your starter is about $20, and you can pick up starter solenoid heat shields for about $20 that only take a little moding to work.
As for your alternator )it body as ground, and back terminal under the rubber boot as positive), should be putting out about 14.7 volts as the car is idling, lights off, and radiator fan not spinning. If the voltage in these conditions is less than this, would start to check the fuses in the fuse box that send reference voltage to the alternator to being with (horn fuse is one of them). So alternator at 14.7, battery down line in same condition should be around 14.5 volts.
Recall C6 fuse blocks replaced under recall?
Power line feeding low beams due to expansion/contraction cracked causing an open. No low beams.
Here again though problem was much more prevalent in hotter climates w/ more extreme temp fluctuations.
Could manifest today in northern tier climates, not due to heat though -- age.
