Map Light Button Position
Old Jul 13, 2020 | 08:33 AM
RobLo's Avatar
RobLo
Default Map Light Button Position
On the rear view mirror, the 2 map lights under the mirror, are they in the "off" position when they are up or when they are down? Manual only tells you to push the button to turn on or off, it doesn't tell you which button position is which...thank you!
Old Jul 13, 2020 | 09:59 AM
2008 Corvette's Avatar
2008 Corvette
2020 C6 of the Year Finalist - Modified
Out is off, in is on. Light will be activated when opening or closing the doors in the out position.
