Drivers seat problem
Any advice would be appreciated
Had a similar annoying squeak a while back that was coming from under the driver seat on my BMW Z3 M Roadster.
I used a spray silicone to apply a thin coat under the seat as mentioned in the article below about fixing squeaks in a normal in-house chair.
To my amazement, it worked, squeak never came back.
https://www.bustle.com/p/the-4-best-...hairs-19242309
If you do remove the seat disconnect the battery before disconnecting the electrical connectors.
