Help with Drags
Old Jul 16, 2020 | 05:43 PM
Dreyna604's Avatar
Dreyna604
Default Help with Drags
So with covid going on its a little tough to find a pair of rear drags with MT ET Rs financed most shops dont have any. So what i did is i purchased a set of c5z wheels 17x9.5 called it a a day. I need a little help my current set up is FBO Huge Cam and E85 weight reduction also im about 490ish 500ish or so. What tires can i mount on these 17x9.5? Can i still get MT ET Rs 305/45/17? Or? Any help is appreciated. TIA.
Old Jul 16, 2020 | 06:18 PM
Turbo6TA's Avatar
Turbo6TA
2021 C6 of the Year Finalist - Modified
I use the ET Street S/S drag radials in 305/45 -17 mounted on 17x11 rear wheels on my 2011 GS
You could do it, but a 9.5" wheel is really a little too narrow for this tire.
I would opt for using a 275/40 -17 drag radial with your 9.5" wide wheel.
Old Jul 16, 2020 | 06:19 PM
Dreyna604's Avatar
Dreyna604
i just feel like its idk little i guess on 275s. I wanna know if snyone in my power range is on 17x9.5 on 305/45/17 or
Old Jul 16, 2020 | 06:25 PM
Turbo6TA's Avatar
Turbo6TA
At 500 or less RWHP, a 275/40 -17 drag radial will be more than enough tire for good 60' times.
You don't really need a 305/45 -17 at that power level.
______________________________
Edit ... In fact, the larger diameter 305/45 -17 tire may actually slow your 1/8 and 1/4 mile trap speed down vs using the 275/40 -17
Old Jul 16, 2020 | 06:30 PM
Dreyna604's Avatar
Dreyna604
oh okay,i guess 275/40/17 it is i just want it to look nice and hook great from rolls. Because street tires right now 285 from a 50 pull doesnt get it done. itll mainly be doing 50-60rolls not much for track since stock rear end, axles etc etc.
Old Jul 16, 2020 | 06:44 PM
Turbo6TA's Avatar
Turbo6TA
Originally Posted by Dreyna604
ill mainly be doing 50-60 rolls not much for track since stock rear end, axles etc etc.
Since your thread was titled "Help with Drags" ... I got the impression you were concerned about launching the car from a dead stop.
Still, for 'roll racing', get a set of the smaller diameter 275/40 -17 drag radials.
BTW .... If you ever plan on driving the car on wet streets in the rain, do yourself a favor and get the ET Street S/S drag radials instead of the ET Street R drag radials. The ET Street R tires are dangerous on wet roads.
Old Jul 16, 2020 | 06:46 PM
Dreyna604's Avatar
Dreyna604
thanks i ordered them already the 275/40/17 et street r, and yea i heard rain with them sucks ill only be swapping them out when going out for runs.
Old Jul 16, 2020 | 06:47 PM
Turbo6TA's Avatar
Turbo6TA
okie dokie
Old Jul 16, 2020 | 11:28 PM
HOXXOH's Avatar
HOXXOH
Don't get yourself hung up on appearance when performance is your goal. There are no bonus points for how good it looks. Been running 275's for years with 1.4 & 1.5 sec 60' times with stock gears/axles and no failures. YMMV
Old Jul 17, 2020 | 01:52 AM
Dreyna604's Avatar
Dreyna604
you're right! Thanks!
Old Jul 17, 2020 | 07:28 PM
Dreyna604's Avatar
Dreyna604
At the track?
To Help with Drags
