Broken Map Light
Old Jul 30, 2020 | 04:55 PM
blu_c6's Avatar
blu_c6
Default Broken Map Light
I was removing a burnt bulb from map light on rearview mirror and it broke. Any recommendations on getting out the piece still stuck in the socket?
Old Jul 30, 2020 | 05:05 PM
Kenny94945's Avatar
Kenny94945
Suggestion.
Disconnect the battery....IMO very important to do so.
Pry up the mirror bezel and remove the mirror from the bottom.
Paper clip through the bulb connector bottom edge where the wires enter and push out the bulb.
Dig out from the connect then vacuum any remaining glass shards.
Good luck.
Old Jul 30, 2020 | 05:14 PM
blu_c6's Avatar
blu_c6
Do I keep the mirror attached to the window?
Old Jul 30, 2020 | 07:25 PM
Kenny94945's Avatar
Kenny94945
Window?
I'd say no.
Try a u tube search on the bulb replacement - and the search can be a similar Chevy model visor to a Vette visor to use as an example.
Pry up carefully on the framing (eg bezel) on the bottom edge that holds the mirrors and the lights.
(The frame is held in place with tiny easily breakable plastic plugs that insert into tiny holes in the cardboard backing of the visor)
Slide the mirror out the bottom of the bezel between the visor and the bezel.
(No need to remove the entire bezel, just lift the lower portion enough to remove the mirror.
This will allow you to fully access the connector that holds the bulb.
You are not alone breaking these bulbs, you can also search this forum for further guidance.
Good luck.
Old Jul 30, 2020 | 08:11 PM
blu_c6's Avatar
blu_c6
Not the visor but the rear view mirror.
Old Jul 30, 2020 | 08:21 PM
2008 Corvette's Avatar
2008 Corvette
2020 C6 of the Year Finalist - Modified
You could pull the fuse for the rear view mirror or unplug it from the mirror and hemo stats to remove broken piece.
Old Jul 31, 2020 | 11:13 AM
Dutch08's Avatar
Dutch08
^^^^^^^^^^ What he said. (worked for me, HF has a bunch of sizes)
Old Jul 31, 2020 | 03:36 PM
Kenny94945's Avatar
Kenny94945
Opps sorry OP, I can't read very well
To Broken Map Light
