Column Lock Issue Back Again !
Old Aug 8, 2020 | 11:21 AM
RoadkingC6's Avatar
RoadkingC6
Default Column Lock Issue Back Again !
Well it's been approximately two years since i had the column lock issue, however this past week it reappeared not sure if the high heat has anything to do with it or not, about two years ago i installed a new immobilizer unit and the bypass and it's been working fine up until this week, the column lock message came up in the DIC a couple of times while driving and finally a couple of days later the car wouldn't start, about two hours later i got in the car and it started right up. So I am now going to bring it in and have the TSB repair done to finally eliminate this problem, my question is before i bring it in should i remove the bypass i installed and bring it back to stock before having the TSB done.
Old Aug 8, 2020 | 12:45 PM
4SUMERZ's Avatar
4SUMERZ
Good question. Since the TSB basically takes that circuit out of the equation, it shouldn't matter.
I personally would remove the bypass before getting the TSB done.
Good Luck
Old Aug 8, 2020 | 03:24 PM
ruxvette's Avatar
ruxvette
2016 C6 of Year Finalist
Originally Posted by 4SUMERZ
...I personally would remove the bypass before getting the TSB done.
Good Luck
I would, too. Once less thing for them to complain about.
Old Aug 9, 2020 | 09:38 PM
VolSince69's Avatar
VolSince69
Copied from another thread on this....
https://www.corvetteforum.com/forums...post1601766679
To Column Lock Issue Back Again !
