2005 corvette electronics dead .
Old Aug 8, 2020 | 03:44 PM
72454's Avatar
72454
Default 2005 corvette electronics dead .
2005 Corvette electronics not working car is dead with the exception s of headlights gas filling door works, with button on car dash .I was able to get into car with the emergency entrance procedure.
Nothing else works does not start no cluster no radio the interior lights work I cant even close the doors all the way because I think it need`s power to activate the mechanism car battery is good full charge connections are good fob batteries are good any ideas would be appreciated....
Old Aug 8, 2020 | 04:51 PM
4SUMERZ's Avatar
4SUMERZ
How did you check the battery? Did you do a load test on it?
Your symptoms sure sounds like a battery with a bad cell, charger shows full voltage charge but it lacks amperage.
Good Luck
Old Aug 8, 2020 | 05:01 PM
Turbo6TA's Avatar
Turbo6TA
2021 C6 of the Year Finalist - Modified
Yup .... A bad battery might show 12 volts when you put a voltmeter on it, but has no cranking amps at all.
Old Aug 8, 2020 | 05:35 PM
72454's Avatar
72454
I will do a load test on it soon but you would think it would let me in the car even if the battery was low thanks you for your help .
Old Aug 9, 2020 | 06:00 AM
449er's Avatar
449er
CF Community Team
Sure sounds like a battery issue to me
Old Aug 9, 2020 | 03:42 PM
marinablu67's Avatar
marinablu67
These cars are like alcoholics in need of a drink, or they get the DTs! Weak battery, and there's no logic to what will or won't work!
Old Aug 9, 2020 | 04:11 PM
Chuckham's Avatar
Chuckham
St. Jude Donor '20-'21
New battery and then a battery tender. First thing I purchased was a battery tender when I bought my C6. Lots of research around these parts convinced me it was the way to go.
72454's Avatar
72454
Thanks I`m buying load tester Monday I hope that`s all it is last year it tool me 5 month`s of working on and off the car to solve my instrument cluster problem ...
Old Aug 9, 2020 | 04:13 PM
72454's Avatar
72454
Thanks i will do that as well once I get it working ....
Old Aug 9, 2020 | 05:00 PM
Turbo6TA's Avatar
Turbo6TA
Exactly how old is the battery in your 2005 Corvette ?
Or, did you just purchase the car not long ago and don't have any idea as to how old the battery is ?
Old Aug 9, 2020 | 05:08 PM
Turbo6TA's Avatar
Turbo6TA
Save the money it costs to buy a battery load tester. Just remove the battery and take it to Autozone or Advance Auto ... They will load test it for free.
Old Aug 9, 2020 | 05:55 PM
4SUMERZ's Avatar
4SUMERZ
. The money you save from not buying a load tester, use towards a good battery maintainer such as a Deltran Battery Tender Plus.
Old Aug 9, 2020 | 07:46 PM
72454's Avatar
72454
Just looked 2 -1/2 years old. I borrowed a neighbour`s load tester with a full charge it stayed in the green for 14 to 15 seconds also cleaned all the terminals good ,car still dead .....If I hook up a second battery on jumper cables would that make any would that tell me any thing ...
Old Aug 9, 2020 | 08:02 PM
Turbo6TA's Avatar
Turbo6TA
If you jump the battery with a known good battery, it should start as long as you have a good set of jumper cables.
After you get it started, you need to put a battery charger on it till it's fully charged ... If it won't hold a charge, replace your battery.
Old Aug 10, 2020 | 09:37 PM
72454's Avatar
72454
2 good battery`s hooked up all connections clean good cables same nothing I know from working on this car it wasn`t going to be easy took the battery back out cleaned all connection beside and below battery tray hooked power from jumper cables with battery out moved and wiggled 4 plugs around on ECM I had them off last year for instrument cluster job a year ago so i think there clean . I will be looking at fuse box under the hood tomorrow with battery hooked up there is about 5 fuses that show no power I don`t know if there switched or not but the rest are all hot ? I will be taking the hole thing apart seems to me when they had that recall for the headlight they had to open this up and jump some bad connections ... .
Old Aug 12, 2020 | 12:47 PM
Landru's Avatar
Landru
At this point might as well get it in the air to check starter & solenoid.
Starter/solenoid go bad due to heat (like AZ) aggravated w/ headers, especially check connections to solenoid.
Solenoid posts are held by a bakelite material which cracks, can result in an open circuit.
USUALLY when this happens there's a complete loss of power; however, there may be variations like yours.
Have starter/solenoid connection thoroughly checked to confirm integrity of solenoid housing.
IF a DIY be damned sure to disconnect battery first, accidentally dead shorting brings great headaches.
G/L, please update w/ solution...or not.
Old Aug 12, 2020 | 11:04 PM
72454's Avatar
72454
Todays efforts inspected starter looks okay Ran another vehicle beside it, with it running 14 volts going to car with a good battery in the car
that rules out any doubt about bad battery inspected the fuse box under the hood nothing out of the ordinary nothing burnt changed relays around
same .Back to basics something not turning on in the car I'm not sure what the chain of command is for fob detection then signal to activate relay
for BCM or ECM something not getting turned possibly faulty computer which one is activated first I`m giving some thought on manually activating
the power train relay I will sleep on it ....cheers
To 2005 corvette electronics dead .
Old Aug 12, 2020 | 11:51 PM
madsonp's Avatar
madsonp
Check the main connectors to the fuse box under the floor board, I've seen where there can be issues with these from passengers pushing down to hard in this area with their feet. See attachment.
Old Aug 13, 2020 | 01:55 AM
72454's Avatar
72454
Already done that with contact cleaner thanks ..
Old Aug 17, 2020 | 02:01 PM
72454's Avatar
72454
I made a fusible test lead with a prob with half a fuse on the end end so I can remove the fuse from the panel and supply power remotely I did this on my Blazer with the ignition off and was
able to raise and lower the window I`m going to try this on the C6 on my window fuse so I can lower the window and close the door If it dont work them Im sure I have a grounding problem
