C6 Rear Main Time
The job is basically the same labor as a clutch job because all of the same parts have to be removed in addition to the rear cover to replace the rear main seal. I do all my own work but from what I can remember the labor for just a clutch job is at least $1500.
So around $1k is labor alone is about right, then you have the cost of fluids/parts, and even rear end re-alignment when the drive line with cradle is put back in, so should be looking at around $1800 in the end.
If someone is quoting you $800 to replace the rear seal, then bank that they are going to find another problem (bait and switch) while they are in there, to get the price of the repair up over the $2k mark for the same amount of work. And yes, clutch and flywheel has to come out, so replace the entire clutch system parts since it will not cost you any more in labor, since they just install the new clutch system when they are putting everything back together.
It makes sense now what has to be done. That is a lot of work time to get to work. I appreciate the data. Have a great day.cheers
