Anyone else have this issue? Any fix?
5th Gear
It seems my brake pedal can lift up easily. Like nothing stops it from coming up. This will mess my taillights up (temporary) and throw the traction control in to a fit (get a check light).
If I smash the gas, it can also cause this it seems at times. Is there some sort of stop I am missing? Or any fix? Never had a car the brake pedal lifts on like that.
Have you tried pulling the codes, if any? This would point to a possible culprit if there are any recorded. A little more detail on exactly what's happening would be helpful as well.
Would double check the brake pedal main rod and bushings to bracket suports first, then check the fit of the brake booster shaft pin to the brake booster rod, but if pedal parts are fine, then would suspect a problem in the brake booster instead.
Hence could be as simple a a C clip that has come out of retainer channel on the booster for the spring assemblies that just needs to be reset.
wideglideleon (08-14-2020)
5th Gear
I guess I should clarify, everything works perfectly and is normal until the physical pedal is in the not pressed position. Then it lifts up. Like the pedal should have ba stop, or a physical connection it doesn't have.
5th Gear
So no joy pulling the booster, but once in hand, you can pull the back side boot to pull the rod parts to see where the problems is.
Most of the time since the packs are C clip retained, it just a C clip that has popped out of its seat.
