SPARK PLUG preferences
Old Aug 17, 2020 | 12:43 AM
BrknWndC6's Avatar
BrknWndC6
Default SPARK PLUG preferences
I have a base C6 and am teadt to do my tune up. Which spark plugs do you all prefer? Any info will help. Thanks all
Old Aug 17, 2020 | 07:56 AM
The Clevite Kid's Avatar
The Clevite Kid
St. Jude 15 Year Donor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15-'16,'17,'18-'19-'20-'21-'22
Default Oem ftw
Get the iridium AC/Delco spark plugs for your base C6. Other brands have from time-to-time caused electrical issues. GM knew what they were doing for the spark plugs.
Old Aug 17, 2020 | 03:44 PM
Dano523's Avatar
Dano523
OEM Plugs will last 100K, and the plugs that you want to use in the motor.
Myself, I pull them about every 30K to clean them up/check the gaps, then use antiseaze on the threads to I can spin them back out in another 30K until they are worn out at the 100K mark. If your just pulling/replacing the plugs every 100K, then don't use antiseaze on the threads, since the threads come pre coated when new.
Same goes for OEM spark plug wires as well, hence good for 100K.
The reason for the two, some after market plugs and wires do not have the correct amount of resistance (works as a RF noise suppressor from the spark plugs back up to the coils), which can cause RF noise in the coils that feeds back to the ECM. When the ECM get enough RF noise through it, and since it controls the voltage on the alternator, the Ecm will lower the standard 14.7 volts output of the alternator to lower voltage, and you will get service charging system trouble messages/codes.
Old Aug 26, 2020 | 11:29 AM
RobJoy's Avatar
RobJoy
I had iridium plugs that lasted 50k (electrode was burned off two of them). My tuner, who installed an aftermarket cam/kit) recommended staying with the iridiums since they will last longer than the copper electrode kind.
Old Aug 26, 2020 | 11:54 AM
Chevyrelic's Avatar
Chevyrelic
I bought some from Rock Auto recently when the rebate was running. Already put the rebate check in the bank...👍
To SPARK PLUG preferences
