View Poll Results: Source of sound?
Shocks ?
2
33.33%
Bushings?
3
50.00%
Leaf Springs?
1
16.67%
Other?
3
50.00%
Multiple Choice Poll. Voters: 6. You may not vote on this poll
Suspension squeak...
Old Aug 22, 2020 | 08:58 AM
corrado's Avatar
corrado
2021 C6 of the Year Finalist - Modified
Default Suspension squeak...
Any guesses what this squeak is on my rear suspension?
VERY noticable going slow over any bumps. Fine at speed (at least not noticeable as car is loud!)
Shocks? Bushings? Car has 150,000 kms, original suspension. I have a good mechanic, just far from me. I usually order my parts myself so I want to know what I need.
Any help greatly appreciated!
https://youtu.be/Mxqh0aI0tj0
Old Aug 22, 2020 | 09:45 AM
sonik_fury's Avatar
sonik_fury
My sway bar bushing were dry as a bone and would squeak and pop regularly. Lubed them with some silicone lubricant and been fine ever since.
Old Aug 22, 2020 | 05:58 PM
4SUMERZ's Avatar
4SUMERZ
Sway Bar bushings would be the first thing I changed when it hit approx 75,000KM's. They tend to clunk when worn out rather than squeak.
I then changed out the shocks to Bilstein B8.
I have 175,000KM's on my 2006, and i do not have any squeaks.
Any item that has rubber bushings is a potential area for squeaks. (sway bar end links, shock bushings, composite leaf spring bushings, lower and upper control arm bushings, rear upper control arm bushings etc.)
As mentioned, spray the bushings one at a time to see if you can isolate the area that is causing the squeak.
Good luck.
Report back when you find the culprit (s)
Old Aug 22, 2020 | 10:47 PM
1rusty1's Avatar
1rusty1
If it's none of the above, you might want to check your exhaust pipe hanger springs. When the coating wears down, it makes quite a racket when it's metal to metal.
https://www.corvetteforum.com/forums...r-springs.html
Old Aug 22, 2020 | 11:28 PM
Zapp Brannigan's Avatar
Zapp Brannigan
Thanks for the link. Talk about a timely post. I heard a little squeak coming from the rear of my 09 tonight with the windows down. That'll be the first thing I check.
Old Aug 23, 2020 | 12:23 AM
Majkowski's Avatar
Majkowski
I had exactly that squeak on my 13 GS this spring and sway bar bushings were the culprit. I just lubed them with some silicone spray but they're looking a little rough, will probably end up replacing them this winter.
Old Aug 23, 2020 | 10:27 AM
corrado's Avatar
corrado
Yes, I did check those too, I know that's pretty common but definitely not them. Thanks!
Old Aug 23, 2020 | 10:29 AM
corrado's Avatar
corrado
Thanks guys! If it is the shocks, I was probably going to upgrade to Bilsteins or Z06 shocks, as I have the rear wide body with 345s.
When I find out the culprit I'll report back.
To Suspension squeak...
