P2127 Code
Old Aug 30, 2020 | 11:21 PM
technoman007's Avatar
technoman007
Default P2127 Code
Hello All,
I have been intermittently getting the P2127 code on a 2009 Automatic(Z51) that says - "Throttle/Pedal Position Sensor/Switch 'E' Circuit Low". It has happened at least 6 times now and the car goes into Reduced Power mode. Below are the steps I have taken so far to troubleshoot, but cannot pin point the problem.
1) Replaced the accelerator pedal assembly ( the code did not come for at least a year and half )
2) Replaced the throttle body ( code went away for a month or two)( Probably there was no need to replace, but tried it anyways)
3) On a Foxwell NT-301 I checked the TP% on live feed and the throttle % increase and decrease with my pedal press and release looks normal.
4) I have searched around corvette forum and found some posts with TSB saying - check the "IP to body harness connector". But I'm not sure what harness its referring to.
5) I have visually inspected the wiring that I can see and reach and I don't see any wire housing breaks or deterioration. I have also checked the wiring around the battery and it looks ok.
If I clear the code, it runs fine for some time and then randomly the check engine light pops up with P2127. In the latest event I got a service traction control on the DIC too, but the code scan pointed to just P2127.
Any thoughts on what else I can try to troubleshoot this code ?
Old Aug 31, 2020 | 12:57 AM
ancona's Avatar
ancona
You could also used an advanced OBD2 scanner to view and also to data log the live voltage readings on both circuits, to see if there are any voltage fluctuations when driving the car.
Old Aug 31, 2020 | 09:35 AM
Landru's Avatar
Landru
If not already performed try force rebooting computers via disconnecting battery a few minutes, reconnect.
*remember to re-index windows once powered back up.
IF this is one of C6's electronic gremlins it might clear code & keep it gone.
Worth a try as this trick has solved many a mysterious codes/issue.
Also, how old's battery?
If >2 y/o, load test it just to eliminate a weak battery as cause.
Common knowledge among longtime owners of C6 a weak battery will create all manner of havoc.
Owners have gone down multiple rabbit holes while racking up a big diagnostic bill when whatever caused it is a fluke easily cleared.
Old Aug 31, 2020 | 10:15 AM
technoman007
Thanks for responses ancona and Landru.
Landru, as a matter of fact my battery is almost 4 years old and it died yesterday. I attempted to charge it for at least 8 hours yesterday and it would not hold any charge. I hope getting a new battery fixes this problem.
ancona, I will monitor the graphs once i change the battery.
Old Aug 31, 2020 | 11:02 AM
Landru's Avatar
Landru
Get a new cell installed, re-index windows and report back to thread.
Sure would be nice if this issue was triggered by a failing cell, or, now completely failed as it were.
G/L
Old Sep 8, 2020 | 10:01 PM
technoman007
I swapped the old battery with a new one and it ran fine for roughly 80 miles. Now the code is back and I have no clue on why.
It was the usual P2127 with Reduced engine power and Service active handling.
What would be the ground location for the accelerator circuit ?
Any thoughts on what could be the problem?
Old Sep 8, 2020 | 11:24 PM
SixAddict's Avatar
SixAddict
https://www.corvetteforum.com/forums...vice-help.html
Maybe this might help. Scroll down to 4SUMERZ post. He provided this.
Old Sep 8, 2020 | 11:57 PM
technoman007
Thanks SixAddict, I hope G104 is the ground that im looking for(since its near the ECM).
Old Aug 12, 2023 | 08:03 PM
Wanted_zo6's Avatar
Wanted_zo6
I know this is years old but I am having the same problem, did the ground fix it?
Old Aug 12, 2023 | 09:56 PM
technoman007
No, my replacement accelerator pedal was bad too. After replacing that I have not had the code.
Old Aug 12, 2023 | 10:51 PM
Wanted_zo6's Avatar
Wanted_zo6
Hopefully that’s all mine is. Thanks for the help!
To P2127 Code
