CAN bus system.
Old Sep 1, 2020 | 10:56 PM
Jason W Dreher's Avatar
Jason W Dreher
Default CAN bus system.
Hi, I'm looking for the location of the CAN bus system.. Pictures would be great as well. Thanks!
Old Sep 3, 2020 | 07:05 AM
luka2sb's Avatar
luka2sb
The CAN bus is a twisted pair of wires that’s wired throughout the entire car. It goes into most modules, it’s not 1 thing U can point to. Most modules have CAN communication. If you are talking about the OBD port, that’s a connector that lets you connect to the CAN bus, and that’s a plug that is about 1 foot below the steering column, roughly between your knees (on a corvette) on most cars the OBD connector is by your left knee where the hood release is.
Old Jan 17, 2024 | 06:14 AM
Toys4Life C5's Avatar
Toys4Life C5
St. Jude Donor '21
Since the person who asked this question didn't thank you for the right answer, I will.
Thank you!
T4L
Old Jan 17, 2024 | 06:28 AM
Dano523's Avatar
Dano523
Two parts to the system, with the high speed land bus shown here, and run on the two wire pair.
Also, you have the class two data, which is run from the major modules, to lower class modules,
Then farther down the line, from modules to senors as well,
As for major control over the high speed lan system, its the BCM, since it sets the vins lan security code/hand shake in the first place, if the modules will talk to each other with the correct hand shake in the first place. Hence just swapping out a module may not work, since it may need to be vin flashed so it does hand shake with the correct vin security code to start with.
To CAN bus system.
