engine noise
Old Sep 5, 2020 | 12:44 AM
mani1128's Avatar
mani1128
Default engine noise
Hi i was driving home tonight normal Cruise then all of a sudden heard a noise as if i was dragging something or even i belt chewed off then went away,few minutes of driving noise came back i pulled over and engine is tapping from top of motor even sounds like bottom hard to tell noticed that oil pressure was lower ive seen like low as 20-34 flickers by 5 sometimes wtf im so depressed now, any ideas ps i had heads redone stage 3 cam 7000 miles since
Old Sep 5, 2020 | 10:42 AM
Dave S's Avatar
Dave S
Retired & lovin' it!
Impossible to diagnose from this limited information but a first guess would be one or more lifters going bad. You state that you recently had engine work done....a common problem leading to lifter damage is reuse of a worn lifter tray or use of a poor quality after-market tray. Either allows the lifter to turn in it's bore which damages the lifter & if not caught early, could damage the cam. Get back to your engine builder for a full diagnosis.
Old Sep 6, 2020 | 08:59 AM
mani1128's Avatar
mani1128
Default Lose lifter
Here’s a vid of what I found
Straight
found broken lifter for the love of god
File Type: mov
Old Sep 6, 2020 | 02:01 PM
Whiteonrice's Avatar
Whiteonrice
So sorry that's really bad.
Rick
Old Sep 6, 2020 | 11:36 PM
mani1128's Avatar
mani1128
Default Lifter fail
Took off head valve piston look fine the lifter I found a piece behind it does the rest when it falls on the cam where can the rest possibly go thanks
To engine noise
