Help
Old Sep 5, 2020 | 08:34 PM
BigAnthony's Avatar
BigAnthony
Default Help
So I installed a new steering wheel and after doing so the radio controls on the wheel do not work AND the volume on the radio itself only goes down not up. As always I appreciate and welcome any and all suggestions. I reconnected all three clips and it all looked good on the inside.
Old Sep 6, 2020 | 12:10 AM
Dano523's Avatar
Dano523
Did you get the correct clock spring for the new wheel (years is not the same as the wheel you just pulled off), and in some cases, swap/added in the new wires to the new clock spring connectors to the needed locations if different year clock springs?
Old Sep 6, 2020 | 09:17 AM
BigAnthony's Avatar
BigAnthony
This morning I start her up and the stereo works fine but the controls on the wheel still don't work.
Old Sep 6, 2020 | 09:28 AM
madsonp's Avatar
madsonp
What are you running for a stereo ? Stock, or aftermarket ? If aftermarket, what brand are you running ? See if this guidance might also help you out.
Old Sep 6, 2020 | 02:59 PM
oldcanuck's Avatar
oldcanuck
I had a problem when I disassembled air bag, steering wheel controls and wheel. When I assembled and tried everything the first time, some things did not work. I took everything apart again and cleaned all connections using q tip and toothpick. Re-assembled carefully. All those tiny parts and connections need to be seated perfectly. When I cleaned and re-assembled thoroughly, everything worked.
To Help
