Hyper Flash Issue....
Old Sep 9, 2020 | 09:22 AM
Bprice812's Avatar
Bprice812
4th Gear
Default Hyper Flash Issue....
Good Morning everyone, new to the forum here and corvettes as well.
Over the last week, I have spent countless hours searching the old interwebs for a fix to my hyper flash issue. One diagnosis after another, I cannot figure out what the issue is. All of the bulbs in the vehicle are factory bulbs. When I press the hazard switch, everything works as it should and the blinkers, blink at the normal rate. Now when I turn either side turn signal on, it is normal for one flash and then immediately moves into hyper flash. It doesn't matter if the vehicle is hot or cold it does it all the time. I also pulled every bulb and verified all of the filaments were intact, which they are.
Any idea what could be going on or how to fix it? I know I could wire in some load resistors to probably fix the issue but I think that could just be a bandaid for the real issue here.
Also, I did use the search function before posting but I didn't find where anyone was having a similar issue. Theirs were either because of LED bulbs, or the flasher unit went bad. Any advice would be much appreciated and thanks for looking.
PFA- Car on the dyno this past weekend.
Old Sep 9, 2020 | 05:10 PM
Landru's Avatar
Landru
Who sold them?
Be damned if I can recall name but CF has a vendor hawking these lights and they're aware of this problem.
If it's the same outfit send 'em an email, they've some kind of harness (IIRC) which solves the flickering issue.
Best of all they'll ship it at no charge.
Old Sep 9, 2020 | 05:29 PM
2008 Corvette's Avatar
2008 Corvette
2020 C6 of the Year Finalist - Modified
Default Hyper flash
Originally Posted by Landru
Who sold them?
Factory bulbs, not LED’s.
Old Sep 9, 2020 | 05:40 PM
GigG's Avatar
GigG
I don't know that I have ever heard of factory lights hyper flashing.
Old Sep 9, 2020 | 05:58 PM
2008 Corvette
Default Hyper flash
Factory bulb will hyper flash on the one that works. Not the one that doesn’t work. Natures way of letting you know one or more bulbs are out. There is no turn signal flasher in a C6.
Old Sep 9, 2020 | 07:58 PM
lobstah24's Avatar
lobstah24
Usually this is from a burnt out bulb. A computer in there somewhere would have read the resistance as too high (an open circuit) for the one the burnt out bulb is in. Thus inducing the hyperflash letting you know there is a burnt out bulb...but it looks like you have that crossed off. You say it does it for both right and left turn signals which leads me to believe that perhaps the previous owner had LEDs and left the resistors in the was preventing his hyperflash. Just a thought...maybe your module is reading a lot of resistance and thinking there is a bulb out. The hazards blink normal because the module tells them to regardless of burnt out lights. Sooooo...look for some extra resistors near your bulb assemblies. Good luck!
Old Sep 10, 2020 | 12:33 PM
Bprice812's Avatar
Bprice812
4th Gear
Good call @lobstah24 , I will start looking through the wiring this evening. Maybe its worth going back to LEDs if the resistors are already there. Also, thanks for the info on the hazard switch. I didn't know that the switch itself would slow down the rate of flash even if a bulb was out.
Thanks to everyone else above as well but yes they are OEM bulbs and flashing fast on both sides, all the time.
Old Sep 10, 2020 | 02:27 PM
Bob Paris's Avatar
Bob Paris
[QUOTE=.... Thus inducing the hyperflash letting you know there is a burnt out bulb...but it looks like you have that crossed off.
Not necessarily. The OP checked the filaments in each bulb and they looked intact. He needs to energize each bulb to see if it is operable or burnt out
Old Sep 10, 2020 | 07:34 PM
lobstah24's Avatar
lobstah24
[QUOTE=Bob Paris;1602159311][QUOTE=.... Thus inducing the hyperflash letting you know there is a burnt out bulb...but it looks like you have that crossed off.
Not necessarily. The OP checked the filaments in each bulb and they looked intact. He needs to energize each bulb to see if it is operable or burnt out[/QUOTE]
Did you read my whole post? The line you specify is referring to the theory of operation of the system.
Old Sep 10, 2020 | 07:39 PM
lobstah24's Avatar
lobstah24
You're welcome. The switch per-say does not slow down the blink rate. The module reads that the hazard switch is depressed and forces the blink rate to be normal regardless of burnt out bulbs.
Let us know what you find...hopefully you will get her done this evening. Like you said if the resistors are there it would be easy to install LEDs.
Old Sep 10, 2020 | 08:21 PM
Bob Paris's Avatar
Bob Paris
Did you read my whole post? The line you specify is referring to the theory of operation of the system.[/QUOTE]
I read your whole post and do not disagree with you. I "disagree" with the OP looking at the filament to determine if the bulb is OK. A bulb can look OK but be bad. I wish the OP luck in solving this.
Old Apr 12, 2022 | 09:55 AM
Jarednk11's Avatar
Jarednk11
8th Gear
I just came across this thread and am having the same issue with my newly acquired C6. Did you ever find a solution?
Old Apr 12, 2022 | 10:01 AM
BadAV's Avatar
BadAV
You likely won't get an answer from the OP. It appears he joined in Sept 2020 to start this thread and last logged in mid Oct 2020.
Old Apr 12, 2022 | 07:39 PM
lobstah24's Avatar
lobstah24
Have you checked for resistors in your C6?
To Hyper Flash Issue....
