New shocks - alignment required?
Old Sep 20, 2020 | 09:24 PM
ki-speed's Avatar
ki-speed
Default New shocks - alignment required?
I'm going to install new Z06 shocks on my 2008 narrow body. Will this work require me to get a alignment?
TIA,
Mark
Old Sep 20, 2020 | 09:26 PM
LouieM's Avatar
LouieM
Mine didn't
Old Sep 20, 2020 | 10:05 PM
buckmeister2's Avatar
buckmeister2
No...the shocks do not support the suspension. They help to control sway and bounce. So, the car will sit at the same height, angles, etc., when it is on the alignment rack, whether the shocks are new or worn. One exception to that would be air-assisted shocks, which, when put under pressure, do support or change the suspension geometry. There are more exceptions, but you get the idea as far as a stock Corvette is concerned.
To New shocks - alignment required?
