Headliner Loose on both sides
Old 09-22-2020, 09:35 AM
Craig Akard
Cruising
Craig Akard's Avatar
Default Headliner Loose on both sides
I have a 2010 Grand Sport Convertible. The other day I noticed the headliner was loose above the passenger door and then yesterday noticed the driver's side was loose. The headliner does not stretch as it once did and fit snug and tight. Is there a cable or a wire that should be attached that keeps it tight or is there another issue that someone is aware of? It is still tight across the top side to side and front to back but it loose just above the doors.
Thanks in advance.
Old 09-26-2020, 07:54 AM
klturn1
klturn1's Avatar
I used 3M Super 77 spray adhesive that I bought at Home Depot in the paint department. Mask everything off really well to avoid over spray. Other than that it's a pretty easy repair. Just follow the directions on the can.
Quick Reply: Headliner Loose on both sides
