Temperature/Cooling fan issues
I ran into some cooling fan issues the other day and I'm wondering if this scenario rings any bells.
I drive a 2007 C6 Base and live in Dallas, Texas area.
The other day, I was driving around and my temps were as usual in the 202-210 range around the city with red lights, etc. All of the sudden, while at a red light, I see the temps go up to 223. hmmmm. This caught my eye because it has never gone that high even during the Texas summer, and this was not a very hot day. ( 217 or so is as high as it goes when stopped in a parking lot waiting for the wife to do some shopping while I wait for her). Once I started moving again, the temperature started going down. I stopped at the grocery store, came out several minutes later, and when I started the car, the temp went to 235. When the engine started, the fan started too, and brought the temperature down to more normal numbers. Normally, I hear the fan staying on even after shutting off the engine, so when I restart it, it's relatively cool. But, not this time....
Any thoughts???
Obviously the thermostat is working.
Obviously the fan is working.
Coolant level is ok.
No codes detected by my code reader.
The thing is that in two years I have owned the car, I have never seen the temp go that high (235) when starting the car even with a hot engine.
Is there a switch that turns the fan ON/OFF after you shut off the engine that could be malfunctioning that is independent/different from the switch that turns the fan ON when the engine/AC is running??
Any suggestions will be greatly appreciated. (My wife's suggestion: it still runs, so keep driving it...
hahaha)Joe
Thx
Given that the fan doesn't fully ramp up until 225, seeing 223 isn't surprising. I've seen that even with a DeWitts rad. The 160 stat will only delay the inevitable for a few minutes if you are stuck in traffic. The only way to get it to run cooler is to modify the fan table so that it ramps up sooner. Do this at the risk of melting the fan connector. In your case, I'd be checking and cleaning the fan connector contacts. I do this every oil change. Checking for debris blocking the air flow is also a good idea, as others have pointed out.
There is also some interaction with the pressure in the A/C system that will cause the fan to ramp up sooner. I take this to mean that if the A/C is working harder, it gets an assist from having the fan work harder too.
Well,
I wonder if the air filters were the guilty parties or not. But, while cleaning the fan, connector, and radiator, I figured I check the air filters. Ordering replacements tonight.
I drove around town and temps were perfect, 194-198 on the highway. Then, I parked in the driveway for about 15 minutes and the temp never went higher than 219.
So far so good. Many thanks for your suggestions. I really appreciate it.
Red dot is on the connector,
Attachment 48334002
Hence if fan table values where lowered, it causes the fan to pull more power than normal, and can melt the connector.
Short of that, start checking the front of radiator for debris that are blocking air flow through them, and may have to pull the A/C condenser forward to clean between it and the front of the radiator itself as well. Hence when you changed the air filter, may have bumped the two to knock some of the crap that was sistered between the two that was blocking air flow.
https://youtu.be/sx4xUnjpkvI
Thanks, Dano.
I checked the connector and it looked normal. Not melted, etc.
I cleaned the air filters until new ones arrive.
I used compressed air to blow the radiator area, fan blades, etc . Not easy without being able to lift the car, but I did the best I could.
Like one of the guys mentioned, I'll get it properly cleaned when we lift the car for an oil change.
The car ran very nice yesterday. No issues.
Im grateful for all the assistance.
Joe
This was a great "experience" because the temperature issue was driving me nuts, and now I have a little better idea of what to look for before I take it to my mechanic and spend a money asking them to do what I could have done myself.
Many thanks!
Changed thermo this past weekend to a 160 w/ water wetter and just idling the highest it’s gone is 187. I haven’t driven it around but I’ve cycled the coolant a few times just letting it idle w/ a cam.
