Brake question
Old Oct 2, 2020 | 10:35 AM
C6Tally's Avatar
C6Tally
Default Brake question
I have a 2010 Vert base and it's time for new brakes. I'm thinking about replacing the rotors, calipers, and pads with something a little better than stock. I daily drive mine and don't track it.
I've looked at Powerstop and Wildwood so far. Most of what I see online says they are not for the magride setup (Which I have)
Have any of you guys replaced all 4 corners with aftermarket setups you would recommend?
Thanks in advance.
Old Oct 2, 2020 | 12:10 PM
Iceaxe's Avatar
Iceaxe
If you have the base JL9 brakes the simplest and cheapest upgrade is to convert to J55 brakes. J55 use the same calipers and pads but have larger rotors.
You will need J55 rotors ($180) and caliper brakets ($300) to make the conversion. Upgrade to a quality brake pad.
Old Oct 2, 2020 | 12:22 PM
919cw313's Avatar
919cw313
2018 C6 of Year Finalist
^ F55 included J55 in 2010.
Old Oct 2, 2020 | 03:11 PM
Carbotech Adam's Avatar
Carbotech Adam
Supporting Vendor
St. Jude Donor '11,'13
Thanks in advance.
How many miles on the brakes? You really don't need a Big Brake Kit AKA (BBK) Depending on your miles a fresh fluid flush, new rotors and a quality brake pad such as the Carbotech 1521 pads. For rotors there is a few options my suggestion for street use stick with OE..
The Carbotech Bobcat 1521™ is our high performance street compound that is our most successful compound. The Bobcat compound is known for its awesome release and modulation, along with unmatched rotor friendliness. Like our AX™ & XP™ line of compounds, Bobcat 1521™ is a Ceramic based friction material offering minimal rotor damage and non-corrosive dust. Bobcat 1521™ offers outstanding performance, even when cold, low dusting and low noise with an excellent initial bite. This compound’s virtually perfect linear torque production provides incredible braking force without ABS intervention. Bobcat 1521™ operating range starts out at ambient and goes up to 900°F. Bobcat 1521™ is suitable for ALL street cars, perfect for your tow vehicle, police cruiser. The Bobcat 1521™ compound has been found to last two-three times longer than OE pads you can purchase at a dealership or national retailer. That’s one of the beauties of Carbotech Ceramic brake compounds. Bobcat 1521™ is NOT recommended for any track use.
Carbotech 1521 brake pads are 100% non-corrosive dust will not harm your wheels, paint or rotors. Carbotech brake pads are 100% made in the USA and can be ordered online here http://ampdautosport.com/brake-pads/corvette/ or call me at 216-780-8825. The part numbers you need are front CT731 and rear CT732. Use promo code z28 at check out to receive your forum discount.
__________________
Adam Adelstein
Amp’D Autosport.com
Internet's largest retailer of Carbotech Performance Brake Pads.
PH:216-780-8825.
Email: sales@ampdautosport.com
Web Site & Direct ordering http://ampdautosport.com/
All major CC and Pay Pal accepted.
Check out Promo code:z28
Old Oct 3, 2020 | 12:27 AM
GettnBetter's Avatar
GettnBetter
Any rotor with slots will be superior. They are all constructed of basic iron. Drilled tends to crack over time. Pads is mostly a matter of dust. Proper bedding of new iron is required.
There are some fancy options with aluminum hubs. I like my Baer's, they are alarming in the garage as all those screws crackle all night during cooldown.
Old Oct 3, 2020 | 11:44 AM
ls1121's Avatar
ls1121
St. Jude Donor '14-'15
I'm going with Powerstop Z23-731 , Z23-732 pads on my 08 Z51. They also have the rotors if you need them. They even sell powder coated calipers if you lean that way. Best Bang for the buck. Carbon Fiber/Ceramic pads #1 choice for me.
To Brake question
