Coolant Leak
Old Oct 27, 2020 | 06:33 PM
quemqn71's Avatar
quemqn71
Default Coolant Leak
2005 Corvette. I am noticing coolant on the garage floor usually in the morning after the car has been sitting overnight. I never see anything during the day while driving about. What could be the source and why only in the morning?
Old Oct 27, 2020 | 06:49 PM
Topduarte's Avatar
Topduarte
Water pump or old hoses
Old Oct 27, 2020 | 06:58 PM
4SUMERZ's Avatar
4SUMERZ
Check all the hose clamps and those hoses for any leaks. Check the overflow tank as well at the hose connections,
Good chance that it is the water pump seal leaking. I had the same scenario on my 06, and it was the water pump seal leaking, but only when it stopped at a certain spot on the shaft of the pump.
Changed out the pump, and no issues since.
Old Oct 28, 2020 | 10:05 AM
Kenny94945's Avatar
Kenny94945
Wow.
Where is the leak?
Front, right, left, center, rear?
Why not jack up the car and take a look?
Old Oct 28, 2020 | 10:24 AM
Josephu's Avatar
Josephu
Could be just from the A/C. Did you touch it,....smell it......taste it if you have to. I bet that its just water.. My 2011 does this all the time.
Old Oct 28, 2020 | 11:05 AM
Landru's Avatar
Landru
Often posted there's a coolant line T-fitting in front of engine.
Bering made of plastic as it ages it cracks causing a leak.
Some members w/ this issue replaced plastic fitting w/ one made of metal.
Difficult to isolate because coolant evaporates due to engine heat until engine's shut off, then it leaks.
Check the T fitting if only to rule it out.
Old Oct 28, 2020 | 05:39 PM
Mad*Max's Avatar
Mad*Max
Did you check the colour, does it have a greasy feel to it?
Old Oct 28, 2020 | 07:21 PM
quemqn71's Avatar
quemqn71
Where do I find the T-Fitting?
Old Oct 28, 2020 | 08:09 PM
Chatman's Avatar
Chatman
A white paper towel can be helpful in determining the color of the fluid.
Old Oct 28, 2020 | 09:25 PM
Iceaxe's Avatar
Iceaxe
https://www.ebay.com/itm/331892668702
Old Oct 29, 2020 | 12:24 PM
GREENKAR's Avatar
GREENKAR
Originally Posted by Iceaxe
I think he wants to locate it on the car as to where it is. Beneath the air bridge near the top of the radiator. That is where the "T" connection is located. Very
Old Oct 29, 2020 | 01:13 PM
Iceaxe's Avatar
Iceaxe
The tee is on top of the radiator, under the air bridge, just in front of the power steering pump.
Replacing the tee is a 5 minute job. I did mine without removing the air bridge. If it's time for a new air cleaner in your car that would be the perfect time to replace the tee as you will have removed the air bridge to replace the filter and access will be extremely simple at the point.
Old Oct 30, 2020 | 01:16 PM
stingray71's Avatar
stingray71
Check the weep hole on the water pump with a mirror and flashlight.
Old Oct 30, 2020 | 03:06 PM
sneal46's Avatar
sneal46
I bought my car from the original owner two weeks ago. When checking the tee (already had the metal replacement), it fell apart in my hands while disassembling the hoses. It was ready to give out at any moment. I also ended up replacing the smaller diameter hose in the tee. It had a rub mark on it from the MAF housing. That would have leaked as well.
To Coolant Leak
