2005 C6 Question
Old Nov 17, 2020 | 03:37 PM
2008 Corvette's Avatar
2008 Corvette
2020 C6 of the Year Finalist - Modified
Default 2005 C6 Question
I have a friend with a 05 Coupe who claims his 05 does not have a key slot above the license plate. He broke his window to get in when his battery died. If you don’t have a 05, please do NOT respond to this post. His car is in storage so cannot confirm. PS. He is not the brightest bulb in the box. Thanks.
Delete.
Old Nov 17, 2020 | 04:00 PM
ssg10587's Avatar
ssg10587
Hey 2008, not sure. Mine has it. 2005 Z51. Have used it before to open the trunk to get to the manual release.
Old Nov 17, 2020 | 04:06 PM
Vette_DD's Avatar
Vette_DD
I previously had 2 different 2005 C6s.
Here's some info. from page 2-15 of the 2005 owner's manual:
If your vehicle has lost battery power, open the
hatch/trunk using the vehicle key. The key lock cylinder
is located on the rear of the hatch/trunk lid above the
license plate. Turn the vehicle key clockwise in the lock.
Old Nov 17, 2020 | 04:13 PM
JasonAndrew's Avatar
JasonAndrew
He probably didnt have the key.
Old Nov 17, 2020 | 04:26 PM
CallawaySC560's Avatar
CallawaySC560
2005: Yes, key slot is there.
Old Nov 17, 2020 | 04:59 PM
2008 Corvette
Default 2005
Yes, he has the key. Thank you for your answers. Like I said he is not the brightest bulb.
Old Nov 17, 2020 | 06:31 PM
stanj1's Avatar
stanj1
I have an '05, and the key slot is there. I know because I've had to use it!
Old Nov 17, 2020 | 06:38 PM
wideglideleon's Avatar
wideglideleon
I have a 2005 and have had to use it also, so it was there from the factory.
Old Nov 17, 2020 | 07:54 PM
BMF_C6's Avatar
BMF_C6
05 here - battery died this past weekend, had to use the key and crawl in an pull the E-door levers.
Old Nov 17, 2020 | 07:55 PM
Smitsd's Avatar
Smitsd
2005 with key slot above rear license plate. Haven’t had to use it yet but I do keep it lubed. Lot of dirt finds it’s way up there. Want to be sure it turns if I do need it.
Old Nov 17, 2020 | 09:11 PM
1bdvet's Avatar
1bdvet
U.S. Air Force
St. Jude Donor '05 thru '26
I also have 05, and there is key slot, perhaps the prior owner did what I did, I used tape to cover the slot from dirt clogging cylinder.
Old Nov 17, 2020 | 09:23 PM
Fine05's Avatar
Fine05
Yep, mine also has one from the factory.
Old Nov 17, 2020 | 09:49 PM
Xctguy's Avatar
Xctguy
MY 2005 has it and use it often!!!
Old Nov 17, 2020 | 11:27 PM
grislyatoms's Avatar
grislyatoms
Just tried mine, works. Knew about it but never tried/used it before. Definitely needs a little lube.
Old Nov 17, 2020 | 11:31 PM
grislyatoms
'05 'vert'.
Old Nov 18, 2020 | 12:22 AM
owc6's Avatar
owc6
'05 Vert here. Over a quarter million miles, and every single mile of that my car had a key slot above the license plate.
Every MY C6 (every version) has that slot in the exact same place, so not sure what your friend thought was going on.
Old Nov 18, 2020 | 03:57 PM
saplumr's Avatar
saplumr
Now you've peaked my interest. I have to ask why you use it often. I've had mine since new 16 years ago and maybe used it twice.
To 2005 C6 Question
Old Nov 18, 2020 | 07:50 PM
blanz's Avatar
blanz
My 05 has the key slot as described.
Old Nov 18, 2020 | 10:11 PM
Xctguy's Avatar
Xctguy
Hey Sapulmr-- Every time the battery fails, drains, or dies, I have that key ready, don't usually carry it with me; just carry the fob to get in the car. Can't get inside a Vette with a dead battery and no key...or can you?? Lucky you, that you haven't locked your keys in the car or had a dead battery..... LOL
Old Nov 19, 2020 | 07:06 AM
05 Wreck's Avatar
05 Wreck
I'm wondering if a previous owner of the 05 removed the lock as a site for a rear view camera? Otherwise, like mine, the lock cylinder is there.
