Throttle position sensor
Throttle Body Assembly
The throttle assembly contains the following components:
• The throttle blade
• The throttle actuator motor
• The throttle position (TP) sensor 1 and 2
The throttle body functions similar to a conventional throttle body with the following exceptions:
• An electric motor opens and closes the throttle valve.
• The throttle blade is spring loaded in both directions and the default position is slightly open.
• There are 2 individual TP sensors within the throttle body assembly.
The TP sensors are used to determine the throttle plate angle. The TP sensors provide the engine control module (ECM) with a signal voltage proportional to throttle plate movement. The TP sensor 1 signal voltage at closed throttle is above 4 volts and decreases as the throttle plate is opened. The TP sensor 2 signal voltage at closed throttle is below 1 volt and increases as the throttle plate is opened.
Yes, no, maybe and just depends on your electronic surgery and reassembly skills.
Hence inside the TB works, you have two re-stat disc's with matching swipers, and most of the time, disc bars just need to be cleaned up, swipers tweaked to put more tension on them to the discs, and Bob's your uncle..
So first sensor is under the gold plate, and the second sensor is deeper down into the works.
Note, if you use the correct size screw driver bits, will not have to drill out anything. Also, mark the disc slot to gold plate and when you put the works back together, make sure that the disc slot lines back up. Also, plain on using a tech II to do a throttle relearn as well (which you will have to do if you replace the TB anyways).
On TB's for the C6 will either be silver vain, or will be gold vain. If you go to replace the TB, make sure that the vain color is the same color at the old one. Hence the different color vain TB's open in the opposite direction then other.
Lastly, would help to have the DTC code, since problem may not be the TB, but the gas pedal sensors isntead. Hence same with two sensor, but since the senor is a PITA (spring loaded, rivet guide pins mouse trap) to pull to clean its re-stat pads and wiper, best to just replace the gas pedal assembly if its sensor is the problem since it only $90.
For what?
The TB does not have store bought replaceable parts, and you are just cleaning up the stock re-stat disc and wipers by pulling the TB apart in the first place.
On accelerator pedal assembly, part number is 19417903 from AC delco.
And again, get the code to see which is the problem to start with, and needs to be resolved.
Getting codes is free at AutoShack or $15 with a cheapie code reader. Please invest the time or money if you want your troubles diagnosed.
So problem is just dirty restat disc surface, not enough swipers pressure inside the TB, with somewhere on sensor 1 as the swipers move along the surface of the Stat pad , it's having a problem with dropped reading for a quick micro second of surface movement in a spot.
Hence if sensor pad or swiper where worn out to not ready at all, then would be getting a different code instead.
P0120 Throttle Position (TP) Sensor 1 Circuit ECM
Not a C6 TB, but gives you the idea of how the disc and swipers work in a Evo TB at least.
https://www.evilution.co.uk/files/sm.../throttle4.jpg
P.S, Too bad your not local, since would have you bring the car over to pull the TB to clean it sensors, and have you back on the road in less than a hour. Once you have a few pull downs and cleans under your belt, only take a few mins with it in hand, with more work pulling the TB off, then doing a throttle relearn in the end once it back on with a tech II.
Many times my experience has been that a C5 that is 23 years old will produce "FALSE CODES"
Does your car seem to be running OK ? other than the codes ? If so they may be false codes due simply to age--1st try to delete all those codes permanently with a mail order tune or with a local tuner---If the problem goes away then in fact they are false codes ----If not 97-98 C5's are prone the throttle body codes---Column lock codes---and ignition switch codes--Start with the simple fixes 1st
