Checking Fuel Senders
Regards, Jeff
That being said, highly recommend replacing with new as fuel senders are a known failure item. The rheostat sweeps lose contact either through the little fingers breaking or a film from high sulfur gas coating the contacts, causing errors.
so if I plug them in and leave the float up on drivers side and move passenger float it should read from half to full.
Then if I leave float down on passenger side and move drivers side it should read from half to empty. Do I have this right?
Thank you for the reply!!
my idiot wisdom leads me to this....
when filling up with gas, the first tank (drivers) fills... which registers the first half of the gauge....
once the first tank is full, fuel spills over via the crossover tube, which starts registering on the second gauge....
you can watch the gauge jump up in steps if you have your window down and car on...
the car then monitors both gauges for level as fuel is consumed... the venturi pump keeps the fuel level the same in both tanks while the electrical pump is operating...
i can get some manual pages for ya later today if you need..
-drew
So if I plug them in and leave the float up on drivers side and move passenger float it should read from half to full.
I was under the impression that the fuel is removed from the pass tank first then the drivers side.
Regards, Jeff
Regards, Jeff
First determine what resistance means "empty" and what resistance means "full." Early C6s (2005-2006) go from 40Ω empty to 250Ω full. The range was reversed in 2007. Later C6s (2007-2013) go from 250Ω empty to 40Ω full.
Your car is a 2007. It should be 250Ω empty to 40Ω full, but I heard somewhere that some 2007s may pre-date the transition. The best thing to do is check your old senders to make sure the resistance moves in the same direction.
With that established, assemble the fuel tanks with the new pumps and senders. With the tanks still out of the car, check the sender signals with your meter. They should read empty.
Turn the tanks upside-down and check again. They should read full.
Testing with the tanks assembled is important because it confirms that the floats aren't hung up inside.
Why?
Cost of removing tanks.
New senders are dirt cheap by comparison to labor accessing 'em.
Can fiddle w/ senders at your leisure to see what they do or don't on the bench.
I don't care what service my rear end needs, if it requires removing tanks senders get replaced. YMMV
Also the gauge works as I typed it in my earlier replies. Driver side float up and pass down reads 1/2 tank. Move pass side float up and gauge goes to full.
Pass side down and move drivers side up goes from empty to 1/2.
Regards, Jeff
FUEL SENDER OPERATION
The fuel level sender changes resistance in response to the fuel level. The engine control module (ECM) monitors the signal circuit of the primary fuel level sender and the secondary fuel level sender in order to determine the fuel level. When the fuel tank is full, the primary and the secondary fuel level sender resistance is low and the ECM senses a low signal voltage. When the fuel tank is empty, the primary and the secondary fuel level sender resistance is high and the ECM senses a high signal voltage. The ECM uses the signal circuit of the primary and secondary fuel level sender in order to calculate the percentage of remaining fuel in the tanks. The ECM sends the fuel level information via serial data circuit to the instrument panel cluster (IPC) for display in the fuel gage.
(The RH tank sender for 2007 and up should test to 247-253 Ohms from Half full to Empty and 38-41.5 Ohms at Full. 2005-06 are opposite of these readings.)
FUEL SYSTEM OPERATION
The fuel system is a returnless on-demand design. The fuel pressure regulator is a part of the fuel tank module, eliminating the need for a return pipe from the engine. A returnless fuel system reduces the internal temperature of the fuel tank by not returning hot fuel from the engine to the fuel tank. Reducing the internal temperature of the fuel tank results in lower evaporative emissions.
Two fuel tanks store the fuel supply. An electric turbine style fuel pump attaches to the fuel tank module inside the left fuel tank. The fuel pump supplies high pressure fuel through the fuel filter and the fuel feed pipe to the fuel injection system. The fuel pump provides fuel at a higher rate of flow than is needed by the fuel injection system. The fuel pump also supplies fuel to a Venturi pump located on the bottom of the left fuel tank module. The function of the Venturi pump is to fill the left fuel tank module reservoir. The primary fuel pressure regulator, a part of the left fuel tank module, maintains the correct fuel pressure to the fuel injection system. The left fuel tank module contains a reverse flow check valve. The check valve, the primary fuel pressure regulator, and the secondary fuel pressure regulator maintain fuel pressure in the fuel feed pipe and the fuel rail in order to prevent long cranking times.
The fuel pump also supplies a small amount of pressurized fuel through the auxiliary fuel feed pipe to the siphon jet pump inside the right fuel tank. The pressurized fuel creates a Venturi action inside the siphon jet pump. The Venturi action causes the fuel to be drawn out of the right fuel tank.
The fuel transfers from the right fuel tank to the left fuel tank through the auxiliary fuel return pipe. The auxiliary fuel return pipe inside the left fuel tank contains an anti-siphon hole in order to prevent fuel from siphoning from the left fuel tank into the right fuel tank. Both the auxiliary fuel feed pipe and the auxiliary fuel return pipe are located inside the convoluted stainless steel crossover hose.
The right fuel tank module contains a secondary fuel pressure regulator. The secondary fuel pressure regulator has a lower set point than the primary regulator in order to allow fuel to flow to the siphon jet pump on the right fuel tank module. When the engine is shut off, the pressure in the feed pipes immediately drops to the secondary regulator set point. This prevents the siphon jet pump from operating and in turn prevents the equalization of the left and right fuel tanks. The secondary fuel pressure regulator maintains fuel pressure in the auxiliary fuel feed pipe which reduces the time to prime the siphon jet pump. The pressurization also reduces fuel vaporization and boiling in the auxiliary fuel feed pipe.
I just wanted to say “Thank You” for all the help I received! I truly appreciate it!!
Wishing everyone a very Merry Christmas and a most wonderful New Year!!
Regards, Jeff
I had the wtong pump on the drivers side. As mentioned above mine is a 2007 and they were two pumps for the C6 and 2007 was a changeover year.
put in correct pump and fuel gauge worked.
Regards, Jeff
