Corvette specs
Old Jan 18, 2021 | 02:44 PM
Richiez's Avatar
Richiez
Default Corvette specs
I own a 2011 C6 Corvette, is there any way I can get the window sticker(specs) information?
Old Jan 18, 2021 | 02:49 PM
449er's Avatar
449er
CF Community Team
Yes, Go to the Corvette Museum website & you can buy a window sticker & build sheet from them, also, the Corvette Black Book is a good source of information for any year Corvette
Old Jan 18, 2021 | 03:00 PM
Vette_DD's Avatar
Vette_DD
What model do you have? There were 7 different models that year. As indicated above, the Corvette Black Book can give you a lot of information about your car and what was available that year.
Old Jan 18, 2021 | 03:19 PM
car2fast4you's Avatar
car2fast4you
You can reprint the window sticker (Monroney Label) for virtually any late model car here:
https://monroneylabels.com/
Old Jan 18, 2021 | 03:22 PM
VetteVinnie's Avatar
VetteVinnie
Aside from the window sticker, you can look in the glove box for the sticker that has all of the RPO codes. Each code, like "Z51", has a decoder that will tell you exactly what is in the car.
Old Jan 18, 2021 | 05:18 PM
Vette_DD's Avatar
Vette_DD
And if you'll tell us what model of 2011 Corvette you have, I can post a listing of the RPO codes definitions.
Old Jan 18, 2021 | 07:21 PM
Iceaxe's Avatar
Iceaxe
^^^ This is the easy route. Monroneylabels.com will charge you $8 for a window sticker.
Old Jan 18, 2021 | 07:23 PM
ruxvette's Avatar
ruxvette
2016 C6 of Year Finalist
Or, take your VIN to your local GM dealer and ask the service department to please print the VIS and build sheet. One will show any repairs done at a GM dealer, the other will show the build date and build options. And, they are free.
Old Jan 18, 2021 | 10:13 PM
JABCAT's Avatar
JABCAT
You can also go here and print your build sheet with all RPO codes for a small fee. https://www.compnine.com/vid.php
Old Jan 18, 2021 | 10:34 PM
Iceaxe's Avatar
Iceaxe
FYI - If you just want to know your cars options there is a sticker on the side of the glove box that lists all the RPO codes for your C6.
You can get a free copy of your build sheet by sending an email to socialmedia@gm.com with your VIN and name requesting a build sheet and they will email you one in PDF format for free.
And as already mentioned... If you want an actual widow sticker https://monroneylabels.com/ is the cheapest, fastest and easiest route.
Old Jan 18, 2021 | 10:37 PM
919cw313's Avatar
919cw313
2018 C6 of Year Finalist
Any GM dealer can reprint the original invoice for the car, too. If they feel like it.
Old Jan 18, 2021 | 11:05 PM
MKenM's Avatar
MKenM
St. Jude Donor '12-'13-'14-'15-'16-'17-'18,'21
Attached is the first Excel spreadsheet that I had put together for the C6 and the Forum. It is for the 2012 model but you can look at the RPO codes on the left and see the description right next to it. If you put x's in col "H" it will calculate the original MSRP. There were not many if any changes in codes. Hope this is helpful.
File Type: xls
Old Jan 19, 2021 | 08:33 AM
BWF07's Avatar
BWF07
St. Jude Donor '11
Oldtimer
Your post title says Corvette Specs, but you are asking where to buy a window sticker and build sheet, as mentioned contact the NCM.
If you are wanting to know what all the options are on your car look in the glove box and you will find a sticker that list all the RPO codes. If you have access to a Corvette Black Book you can see what most mean, but not all of them, but all the major ones. Here is a page that may answer a lot of your questions, 2011 Corvette Tech Center - Corvette Action Center
To Corvette specs
