Need a Tech2 expert!
Old Jan 19, 2021 | 08:02 PM
teebee's Avatar
teebee
2021 C6 of the Year Winner - Unmodified
Default Need a Tech2 expert!
I'm wondering if an ECM can be reprogrammed with a different VIN to make it work in another car. I've got another ECM but it won't work because of the wrong VIN programmed.
If so, can someone step me through the menu structure to get where I can do it.
Old Jan 19, 2021 | 08:28 PM
rkj427's Avatar
rkj427
Pro Mechanic
check out this video..................... pay attention at the 3:00 minute mark, let me know if you want a Tech II users manual, I could email it to you
Old Jan 19, 2021 | 08:39 PM
Dano523's Avatar
Dano523
Will need to install the new ecm in the car, then SPS firmware flash the ECM to vin it to the car.
If 2009 or older, than can use Tis2000, while is 2010 or newer, will need to use TDS on line.
Hence standard version of Tis2000 only goes to 2009.
As for either tech II or Vx GM nano, either can be use with a laptop, with them in pass through mode.
Old Jan 19, 2021 | 11:34 PM
teebee's Avatar
teebee
https://www.youtube.com/watch?v=70_5IPKFICI
So, do I have to install some program onto a computer (like in the vid) or can I go directly with the Tech2? Or is that if I want to update the rest of the software?
Old Jan 20, 2021 | 07:24 AM
rkj427's Avatar
rkj427
Pro Mechanic
sent you a couple PM's earlier.................... software programs may be available online in CD form?????
Old Jan 20, 2021 | 12:08 PM
Dano523's Avatar
Dano523
The tech II will be used as a pass through device/module from the car to the laptop,
and will need either cracked Tis2000 if the car is 2009 or older loaded on the laptop, or will need a TDS account and TDS software on the laptop if the are is 2010 or older.
https://www.acdelcotds.com/subscriptions
Old Jan 20, 2021 | 07:52 PM
teebee's Avatar
teebee
Ok thanks guys for the help.
Old Jan 21, 2021 | 05:01 PM
Dano523's Avatar
Dano523
What year car, and what tech II do you have? Hence hand held clone, or VX GM nano.
If Nano, and 2009 or older, can hook you up with a working copy of Tis2000, and Bob's your uncle since it comes with a working USB cable to connect it to the laptop.
If hand held, then will need the correct USB cable and driver if you don't have a USB cable to connect the Tech II to your laptop to use Tis2000.
https://www.automationdirect.com/adc...bles/usb-rs232
And if 2010 or order, then ac delco TDS ($40 for 24 months of SPS programming), since TDS2000 only goes up to 2009.
Old Jan 21, 2021 | 08:53 PM
teebee's Avatar
teebee
Actually is an 07 Cadillac CTS and a Tech2 clone.
Old Jan 21, 2021 | 11:22 PM
Dano523's Avatar
Dano523
Will need the USB cable (if you don't have one) to connect the hand held Tech II clone to the laptop since laptops have not had Rs232 ports in a long time (cable that came with the unit to connect it to a computer), but email me with a phone number so we can talk and I can hook you up with TIS2000 to firmware flash.
Hence win 10 laptop with dual core processor to run VM player, and the TIS2000 is build in XP shell to run under the VM player.
As for laptop, just make sure you can install VM player on it, and it will be good to go.
https://www.vmware.com/products/work...valuation.html
To Need a Tech2 expert!
