Light changing question
Old Jan 30, 2021 | 09:11 AM
DrFeelgood1987's Avatar
DrFeelgood1987
Default Light changing question
Hey forum!
I'm working on swapping out all the original lighting with LEDs and came across an issue. I ordered everything from Vette Lights and so far everything is great. When swapping out the high beams there is a bulky ballast and plug harness that comes with them. I'm not seeing any place to mount it where it won't b e visible. Has anyone else done this switch out? If so, where did you mount or hide the ballast? Any pictures would. be great as well.
Thanks in advance!
Old Jan 30, 2021 | 09:26 AM
shaggyvette's Avatar
shaggyvette
St. Jude Donor '10-'11-'12, '19, '21
Call /Cole at Vette Lights.. He's very helpful.
Old Jan 30, 2021 | 09:55 AM
DrFeelgood1987
Thanks.
I sent a message through the website, but did not hear back. I checked and they are closed on the weekends so I guess I have to wait until Monday to call. Guess this project isn't getting done this weekend.
Old Jan 30, 2021 | 07:50 PM
DrFeelgood1987
Default Light Changing Question
Update on my lighting issue.
After an exhaustive search on Google, You Tube and the forum I found nothing to help on the installation of the LED/HID high beams from Vette Lights. Am I possibly the only person to get these? I saw a video for another similar type without the big bulky ballast and resistor harness that was much easier to wind up and tuck away., but nothing on the ones I got. I found videos for their fog lamps, low beams and switchbacks, all of which I ordered and installed without issue. Bit nothing for the high beams.
Also, if anyone has upgraded or switched out their high beams, were you able to put the dust cover back on? The video I found for the other type showed the cover would not fit back on so they just left it off and clipped the cover back over the opening. Not sure I like the idea of that.
Should I just skip this upgrade altogether?
Lastly, as part of the install I tested both lights and one works and one doesn't. Has anyone ever had this issue with Vette lights? All the other lights I bought from them work awesome. I'm not sure if it can be replaced or if I just have to scrap this and just leave the factory high beams in place.
Any feedback will be greatly appreciated.
Thank you!!
Old Jan 30, 2021 | 07:57 PM
Mad*Max's Avatar
Mad*Max
Thank you!!
I would upgrade the fogs instead.
Old Jan 30, 2021 | 08:03 PM
2008 Corvette's Avatar
2008 Corvette
2020 C6 of the Year Finalist - Modified
LED’s typically don’t need a ballast. Leave them alone as they are unless Vettelights as a definitive answer. How often do you really use your high beams ?
Old Jan 30, 2021 | 09:16 PM
DrFeelgood1987
Mad Max,
I already did the fogs, lows and the DRLs with the switchbacks. I just figured if I was doing a full lighting change on the car I might as well swap everything out.
Old Jan 30, 2021 | 09:22 PM
DrFeelgood1987
2008 Corvette,
My apologies, I meant that the new lights are the high beam HID conversion kit. I'm waiting to hear back from them. If theres no simple fix or other alternative I'll just leave the stocks.
I do use them on and off as some of the back roads here have no lights on them. I'm thinking with the new fogs and lows I probably won't need them. I just figured I'd swap them all out, but I can live without them I guess.
Thanks for the feedback.
Old Jan 30, 2021 | 09:26 PM
Mad*Max's Avatar
Mad*Max
Mad Max,
I hear ya, when I had my C6 I felt the same way (already had the HID fogs done) but just never got around to doing the high beams. On country roads the superior high beams definitely will help.
Old Jan 30, 2021 | 09:30 PM
DrFeelgood1987
Mad Max,
That was my thinking, but if there is no easy solution, I'll live without them.
Old Jan 31, 2021 | 12:39 PM
madsonp's Avatar
madsonp
I originally installed the high beam HID kit on mine, and I didn't like them because they take a while to warm up to full brightness, I ended up buying the Morimoto LED C7 style headlights from Vettelights instead, which are sooooo much better than the stock lights. If you do stay with the HID's, you don't want to leave the dust cover off, otherwise you'll get dust/dirt on the inside of your headlight housing. If I remember correctly, what I did with mine was to cut a small hole in the dust cover to feed the wires through, then sealed it up with some silicone, then there was a spot I could tuck the ballast into behind the headlight, that I secured with 3M VHB double sided tape, which you can find at Ace Hardware. I've since also added the Morimoto fog lights
Old Jan 31, 2021 | 01:42 PM
2008 Corvette
Default Lights
If I remember correctly JW Motorsports has a LED high beam that I used in mine and the cover went back on no problem. I will have to go back in my log and look for the number.
Old Jan 31, 2021 | 03:58 PM
madsonp's Avatar
madsonp
This was the area I tucked the ballast into when I had the HID's
Old Jan 31, 2021 | 10:46 PM
wjnjr's Avatar
wjnjr
HID hi beams are not a good idea. LED hi beams are a great idea. Send the HID kit back & get the LEDs.
Old Feb 1, 2021 | 06:26 PM
info@umnitza.com's Avatar
info@umnitza.com
Supporting Vendor
This ^
If you want a good quality LED for the high beams and fogs, you can go with Morimoto 2Stroke 3.0 (we sell those) or our own house brand Luxen kit here:
https://www.umnitza.com/luxen-v3-led...men-6000k.html
For fast start, flash to pass operation, you cannot beat LED, HID aren't designed for that.
Old Feb 2, 2021 | 12:14 AM
VetteLights's Avatar
VetteLights
Supporting Vendor
Thank you!!
Great speaking with you earlier!
Reversing the connector to reverse the polarity should get that second light firing right up but let me know if that is not the case and we'll get it taken care of for you!
Our HID Kit will allow re-use of the dust cap. This is one of the major advantages of going the HID route - ensuring no moisture/dirt/bugs are able to get inside the assemblies if the covers were to be left off. Most LED bulbs (at least ones with any notable level of output) will have a large cooling fan base that will inhibit being able to reuse the dust caps - using something like this leaves the door open for moisture buildup, dirt accumulation, and critter nesting. We do also have some high-powered LED high beam bulbs that will still allow the dust cap usage but typically recommend HID over LED solely for the fact that it uses the optics better and creates a more ideal beam pattern compared to what an LED will in my personal experience.
Yes! This is exactly where I mounted the ballasts on my personal set also - no issues at all!
To Light changing question
