Impact Wrench Recommendations
Old Feb 3, 2021 | 05:52 PM
ip-do-tan's Avatar
ip-do-tan
Default Impact Wrench Recommendations
These old muscles are having a hard time removing lug nuts with a breaker bar. Looking for impact wrench recommendations. My compressor is only 5 gallons so I believe the pneumatic type is out of the question. So, that leaves me with battery or 110v versions.
Comments appreciated.....Dan
Old Feb 3, 2021 | 06:06 PM
racerx3317's Avatar
racerx3317
I have an old Snap On that I love and still works like a charm. Pricey though.
Old Feb 3, 2021 | 06:31 PM
killain's Avatar
killain
Oldtimer
I have a really good 3/8 Ryobi impact wrench.
Old Feb 3, 2021 | 06:36 PM
Chatman's Avatar
Chatman
I bought Amazon’s Enertwist. Claims 1050 bolt breakaway ft lbs and 450 tighten. Who knows? So far so good on the Corvette and Navigator. $70. It is corded.
Old Feb 3, 2021 | 07:06 PM
Sdk8103's Avatar
Sdk8103
I have a couple of Kobalt impact wrenches and they work great.
Old Feb 3, 2021 | 08:55 PM
Velocity31's Avatar
Velocity31
Hilti 22v cordless impact. I have every cordless tool in their arsenal and they are superior to anything out there bar none.. We switched everything from Milwaukee to Hilti about 3 years ago. Buy the best the 1st time. Do it nice, or do it twice. 👍
Old Feb 3, 2021 | 09:25 PM
1968swbbigblock's Avatar
1968swbbigblock
I’ve had the Milwaukee high torque impact for about 5 years and it’s been
flawless 1000 ft pounds impact 1400 ft pounds release
https://www.ohiopowertool.com/p-5487...t-2767-22.aspx
Old Feb 3, 2021 | 09:46 PM
Xander617's Avatar
Xander617
same, great tool
Old Feb 3, 2021 | 09:59 PM
Spaceme1117's Avatar
Spaceme1117
I have a Dewalt electric impact.
https://www.amazon.com/DEWALT-DCF899HB-Brushless-Torque-Impact/dp/B00WJA1J68/ref=sr_1_26_sspa?dchild=1&keywords=dewalt%2Bimpact%2Bwrench&qid=1612407447&sr=8-26-spons&smid=A3SPLR0MSOYZ8O&spLa=ZW5jcnlwdGVkUXVhbGlmaWVyPUEzSkVLTVc0V1hPRTZHJmVuY3J5cHRlZElkPUEwODc5NTI4M0xKQ1I3NUlQUUFDMyZlbmNyeXB0ZWRBZElkPUEwNzYyMzQ0MUI2SlNLMFUxMTdRRSZ3aWRnZXROYW1lPXNwX210ZiZhY3Rpb249Y2xpY2tSZWRpcmVjdCZkb05vdExvZ0NsaWNrPXRydWU&th=1 https://www.amazon.com/DEWALT-DCF899HB-Brushless-Torque-Impact/dp/B00WJA1J68/ref=sr_1_26_sspa?dchild=1&keywords=dewalt%2Bimpact%2Bwrench&qid=1612407447&sr=8-26-spons&smid=A3SPLR0MSOYZ8O&spLa=ZW5jcnlwdGVkUXVhbGlmaWVyPUEzSkVLTVc0V1hPRTZHJmVuY3J5cHRlZElkPUEwODc5NTI4M0xKQ1I3NUlQUUFDMyZlbmNyeXB0ZWRBZElkPUEwNzYyMzQ0MUI2SlNLMFUxMTdRRSZ3aWRnZXROYW1lPXNwX210ZiZhY3Rpb249Y2xpY2tSZWRpcmVjdCZkb05vdExvZ0NsaWNrPXRydWU&th=1
I have used it to remove the harmonic balancer bolt; zipped it right off. Just don’t use it to put the lug nuts on or you will rip the studs off.
Old Feb 3, 2021 | 10:33 PM
FAUEE's Avatar
FAUEE
Home depot has (or had last time I was in there earlier in the week) a kit with this tool, the m12 electric ratchet, and batteries and charger for 200 bucks. Was thinking I need to pick it up.
Old Feb 3, 2021 | 10:36 PM
KevDude's Avatar
KevDude
I have two Ridgid battery operated impact tools. Rigid makes great products for a decent price.
Old Feb 4, 2021 | 03:40 AM
Don-Vette's Avatar
Don-Vette
I use a 1/2" Dewalt20 volt MAX XR with 4Ah battery.https://www.homedepot.com/p/DEWALT-2...99M1/206387892
Old Feb 4, 2021 | 05:22 AM
Grandpa1's Avatar
Grandpa1
I bought a Harbor Freight electric 1/2" impact wrench for $30 or so. It's a Chicago Electric brand and it works great.
I've used it a ton and like it.
Good luck!
Old Feb 4, 2021 | 06:57 AM
Patsgarage's Avatar
Patsgarage
I have used several of the 110v impact guns (DeWalt, Milwaukee & HF) and while they all do a good job they are very heavy. I think that the majority of the battery powered ones are lighter, so I suggest shopping for one in person as opposed to online.
Old Feb 4, 2021 | 11:48 AM
Dutch08's Avatar
Dutch08
I have a battery powered Ryobi (worthless) and a cheap Harbour Freight air powered impact that is perfect for home DIY use (In a Professional shop I don't know if it would hold up).
Here's a guy that tests equipment, it might give you an idea of what will meet your needs.
Old Feb 4, 2021 | 11:50 AM
64drvr's Avatar
64drvr
St. Jude Donor '15
Milwaukee M18 high torque is the gold standard.
Old Feb 4, 2021 | 12:27 PM
TraceZ's Avatar
TraceZ
My recommendation as well. Awesome tool.
To Impact Wrench Recommendations
Old Feb 4, 2021 | 12:43 PM
MysteryMob's Avatar
MysteryMob
I also have the Milwaukee high impact, and it's great. I hope they eventually go to the newer style multi-LED design, but it's still a great tool.
Old Feb 4, 2021 | 01:12 PM
LilNutSac's Avatar
LilNutSac
One day, I hope to own a Milwaukee M18 impact. 4-way tire iron has worked well for the last two decades though. REALLY wish I had it removing my leaf spring mount bolts. Shoulders hurt just thinking about it. Most blue locktite I've ever seen on four bolts!
Old Feb 4, 2021 | 02:23 PM
MysteryMob's Avatar
MysteryMob
I thought the same way, used to only use the pneumatic impact or regular tools. However, I now have the Fuel high-torque impact, Fuel Ratchet, Fuel Hammer Drill and Impact driver, and I cannot believe how much easier it is to work on everything. Wheel lugs loosened? Seconds. Removing every single header bolt, even when stubborn? Less than a minute per side. My friend was hand-loosening one of the hard-to-reach bolts and I had the entire driver's side done before he had even finished that single one.
My shoulder and hands thank me every time I work on the car, and I highly recommend it.
