C6 Corvette Diff question
Old Feb 8, 2021 | 12:37 PM
SaltyVette408's Avatar
SaltyVette408
1st Gear
Default C6 Corvette Diff question
Hello, im a noob in the forums but I have a questions that I can't find the answer too. I've looked in the forums but im still lost. I have a 2005 z51 corvette M6. I broke 4th gear. I'm replacing the transmission with 2006 corvette M6 Transmission my friend sold to me. I found a diff from a 09 corvette that had a tr6060. Would that diff be compatible with my 2006 transmission ? Thanks in advance.
Old Feb 8, 2021 | 07:27 PM
backlash2032's Avatar
backlash2032
As long as both the trans and diff are base model, then yes.
Old Feb 8, 2021 | 07:52 PM
BMF_C6's Avatar
BMF_C6
I would check and double check, I do know that the diff in the 05 is different than the 06's and up. When my son blew the diff and I had it replaced with a RPM STG4 there was a special bracket that had to be supplied to make it work with the 05.
I am no specialist but I do know that the 05 first year of the C6's that the rear diff is the weak link in the drive train which was corrected in 06.
Good luck
To C6 Corvette Diff question
