Not the Same
Old Mar 15, 2021 | 08:00 PM
jeb182's Avatar
jeb182
Default Not the Same
Before everyone goes off on me for posting a thread about windows not indexing be patient.
Battery went dead and of course the windows and driver's seat lost all memory. After several tries I finally got the driver's door window to index. Several tries. I tried the passenger window and thought I had it. Now it will not index again. While trying to reset it the window stuck in the down position twice. After several tries it went up all the way. Still could not get it to index. The driver's seat would also not move to the preset position. I reprogrammed it several times and it would maybe work. After driving it again I tried to move the seat to the programmed position and it would only move about one inch. I would reprogram it and it would do the same thing each time I drove it.
I disconnected the battery and let it set about a half hour. I was able to set the driver's window to index properly and I think the seat will now move to where it is set. Passenger window still a problem. I took the door panel off and everything seems to be fine. While messing with it and the window down about an inch I shut the door and the friggin window went up perfectly. I tried it again and it went up. Now it won't even do that at all and I still can't get it too index. I have disconnected the battery in a last ditch attempt to get everything to work as it should, but if this doesn't work I don't know what to do. I am letting it set for an hour.
There has got to be a switch somewhere for the window indexing, but I have no idea where. Anybody have any ideas on what to try next.?
Old Mar 15, 2021 | 08:14 PM
1bdvet's Avatar
1bdvet
U.S. Air Force
St. Jude Donor '05 thru '26
Try reading owners manual, might have something you are missing!
http://www.c6registry.com/Technical/manuals/2005OM.pdf
Old Mar 15, 2021 | 08:17 PM
jeb182's Avatar
jeb182
I have read the owners manual. I'm doing it correctly as the manual states.
Old Mar 15, 2021 | 08:56 PM
D-Dub2013's Avatar
D-Dub2013
Did you replace your battery after it went dead? If not, you may want to try changing the battery. Batteries can cause weird electrical issues on these cars.
Old Mar 15, 2021 | 09:02 PM
2008 Corvette's Avatar
2008 Corvette
2020 C6 of the Year Finalist - Modified
Default Window
Do this procedure with both doors CLOSED.
Old Mar 15, 2021 | 09:29 PM
lobstah24's Avatar
lobstah24
^^THIS^^
If that doesn't work and you have not replaced your battery then that is the next step. A failing battery can cause A LOT of havoc in these cars.
I've recently replaced my battery after the original OEM failed...mine indexed fine.
Old Mar 15, 2021 | 10:34 PM
jeb182's Avatar
jeb182
New battery. Both doors closed.
Old Mar 17, 2021 | 11:38 PM
Knob Jockey's Avatar
Knob Jockey
St. Jude Donor '11-'12-'13-'14-'15
Another thing to check is that the 2 large blue connectors in the passenger-side foot well are clean and fully seated.
Old Mar 18, 2021 | 08:48 PM
jeb182's Avatar
jeb182
I will check the two connectors and see what happens. There has got to be some switch or something that might be bad doesn't there? I keep hoping that it will just suddenly work.
Old Mar 19, 2021 | 01:14 PM
dr_gallup's Avatar
dr_gallup
Battery change should not affect drivers seat memory positions at all. The only thing that should be lost is the window indexing. You've got something else still bad like a ground connection, etc.
To Not the Same
