Brake fluid
Old Mar 16, 2021 | 02:27 PM
okgo's Avatar
okgo
Default Brake fluid
2012 grand sport convertible can you mixDot.3 with Dot4 I did it by mistake thanks in advance
Old Mar 16, 2021 | 02:49 PM
Dano523's Avatar
Dano523
Your fine, but would still power flush the system to just have one type of fluid in the system.
Dot 4 has a higher boiling point, while Dot 3 will absorb humidity out of the air at a slower boiling point instead.
As for Dot 4, tend to advice street guys, and some auto cross guys to use Preston Dot 4 on the C6. It has the highest boiling out of all the less expensive type dot 4 fluids. So under $14 for a quart of it, verse some race type dot 4 fluid with higher boiling point that would cost $80 per quart of instead.
Note, I use about a quart of fluid when doing a power flush of the brake system, including cycling the ABS pump to get the old fluid out of it as well.
https://www.lelandwest.com/brake-flu...ison-chart.cfm
To add, service manual calls out for the brake fluid to be power flushed every 2 years, and on most C6's, have not been power flush in over 10 years, with the old brake fluid saturated with water to cause corrosion problems inside the brake system instead.
