Tune
Old Mar 21, 2021 | 06:54 PM
Vette'nFender's Avatar
Vette'nFender
Default Tune
What does an LS2 tune consist of?
Old Mar 22, 2021 | 08:29 PM
Dave S's Avatar
Dave S
Retired & lovin' it!
Like in the olden days of adjusting spark advance by rotating the distributor & adjusting fuel mixture by replacing carburetor jets or adjusting idle speed/mixture, today's engines are "tuned" electronically by use of software programs that adjust settings in the ECM. There's much more to it, including "tuning" of auto tranny's (if so equipped), but this is a basic explanation. If you're looking at getting a tune, I would strongly recommend East Coast Supercharging (ECS) just across the river from you in Cream Ridge NJ.... https://eastcoastsupercharging.com/
609-752-0321
Old Mar 23, 2021 | 03:31 PM
flyingbunnys's Avatar
flyingbunnys
o Diagnostics & Evaluationso Tuning for all performance modificationso Transmission Tuningo GM SPS Computer Updateso Chip “burning” and programmingo Dyno Test Runs & Performance Reportingo Wide-Band Air Fuel Measurement with bung installationo Custom Fuel Mapping, Ignition/Spark Mapping
I pulled the above from Tony's Corvette Shop in Gaitgersburg Maryland where I had mine tuned. It also is not that far from you either.
Old Mar 23, 2021 | 04:59 PM
Vette'nFender
Thanks for the input...now next question, what does a tune like the one in your description cost?
Old Mar 23, 2021 | 05:35 PM
flyingbunnys
Mine didn't include everything listed there since i want aiming for high performance and wasnt interested in any dyno runs.
I had to get mine tuned because the previous owner had done a diy tune and had really messed up the shift points and fuel mixtures.
The full performance tune with dyno pulls would likely cost more than what i paid. It was a while ago i don't remember the exact cost but it was several hundred dollars.
Old Mar 23, 2021 | 05:50 PM
D-Dub2013's Avatar
D-Dub2013
A good dyno tune usually runs in the $400 to $600 neighborhood.
Old Mar 23, 2021 | 09:13 PM
farmington's Avatar
farmington
If you are all stock or close to it, a tuner can do a “street Tune” without the dyno and you will notice the difference. Would probably be $150 less
Old Mar 24, 2021 | 10:55 AM
D-Dub2013's Avatar
D-Dub2013
A "Street" tune the tuner should drive the car...and usually with a dyno tune the tuner does that too...so just put the car on the dyno.
Or with a cann'ed tune you need to buy some tool or another to load the tune, so by the time you buy that and then load your tunes, the dyno tune would be done with correctly and for less $.
To Tune
