Battery Size
Old Mar 22, 2021 | 09:24 AM
skybolt31's Avatar
skybolt31
Default Battery Size
I just purchased a 2013 that has the original battery which I am looking to replace. The one in the car that the original owner says came with the car is a Group 85. When I look for replacements, some say Group 85 and some say Group 90. I have done a search of previous posts and have found people asserting both were original equipment. Is there a difference between them or would either one work? I am planning on stickling with a AC Delco battery mostly because it would look appropriate.
Old Mar 22, 2021 | 11:07 AM
gdmoore01's Avatar
gdmoore01
Do an internet search on "Auto Battery Group Size Chart". See the attachment for the following battery group sizes recommended to fit a Corvette.
I put a Duracell AGM group size 35/85 in my GS. The taller battery offers a higher CCA rating than stock, but the extra height may interfere with changing the cabin air filter, so you might have to shift the battery to replace.
Hope this helps.
GD
File Type: pdf
Old Mar 22, 2021 | 11:34 AM
backlater's Avatar
backlater
Lookup an H5, basically the same size with more capacity.
Old Mar 22, 2021 | 01:54 PM
Turbo6TA's Avatar
Turbo6TA
2021 C6 of the Year Finalist - Modified
If you have a C6 with the wet sump engine (battery in the engine compartment), it's group 85.
Maybe the dry sump C6 cars that have the battery in the rear use a different group number ?
Old Mar 22, 2021 | 02:27 PM
skybolt31's Avatar
skybolt31
Thanks for the info, I was able to locate an AC Delco PG85 that looks like the one that was in there. I don't know if they are better or worse than any other brand, but it looks like it belongs there.
To Battery Size
