Front Camera Wire Run
Old Apr 1, 2021 | 11:30 PM
msm07c6's Avatar
msm07c6
Default Front Camera Wire Run
Anyone run camera wiring through the hood latch cable grommet? Or, bad idea? I checked tonight and it seems the latch cable housings remain pretty stable when the inside handle is pulled. And, it’s not like they’d be in constant motion.
I have cameras and a new HU to install...probably going to wait and do it all at the same time as the lower shifter box. Just trying to have a decent plan.
Old Apr 1, 2021 | 11:54 PM
smhigh's Avatar
smhigh
Veteran: Marine Corps
Old Apr 2, 2021 | 12:53 AM
madsonp's Avatar
madsonp
I ran mine through the grommet for the main wiring harness behind the battery (red arrow), another option is where I ran the power for my amp which would require drilling a small hole in the firewall (yellow arrow). This is assuming your battery is under the hood and not in the back of the car.
Old Apr 2, 2021 | 08:27 AM
JABCAT's Avatar
JABCAT
I ran mine up under the driver’s side fender, under the A-pillar and into the car. Follow the wire bundle under the knee bolster/steering wheel and then to the back the head unit. Easy to do, easy to get to if you ever need to change/remove it.
Old Apr 2, 2021 | 02:33 PM
TripleB5832's Avatar
TripleB5832
^^^^^What he said. I ran mine through the main grommet too......
Old May 30, 2024 | 07:59 AM
Itsa10_droptop's Avatar
Itsa10_droptop
7th Gear
How'd your install go? Did you take pics?
Old Jun 1, 2024 | 04:57 PM
4SUMERZ's Avatar
4SUMERZ
I ran mine just above the hood release cable grommet by drilling a small hole then sealing it once the camera wire was run through. No issues
Old Jun 1, 2024 | 05:06 PM
msm07c6's Avatar
msm07c6
Originally Posted by 67covette;
about to ask same questions
Well, I decided in the end that I didn't need that front camera. I just learned how to judge where curbs and wheel stops are when parking. Other than introducing the front end of my car to a concrete highway barrier this past Tuesday (no camera was gonna prevent that!), I've had no issues without it.
To Front Camera Wire Run
