EOS zr1 side skirts missing hardware
Old Apr 2, 2021 | 05:53 PM
Jake2212's Avatar
Jake2212
Default EOS zr1 side skirts missing hardware
I bought these to put on my car, but they didn't come with any hardware, just some double sided tape. does anyone know what screws/bolts/nuts I would need and how many? I tried sending them an email asking for the info but never got a response, so I just hope somebody knows what I need so I can go buy it and put these things on. thanks!
Old Apr 2, 2021 | 06:15 PM
SixAddict's Avatar
SixAddict
This is what I used for my fiberglass C7 Carbon side skirts. Even though they came with hardware I heard better reviews using these.
Old Apr 2, 2021 | 06:33 PM
Jake2212's Avatar
Jake2212
thanks! what about where the splash guards meet with the side rocker? also did you use this to attach the splash guards to the wheel well as well?
Old Apr 2, 2021 | 07:18 PM
SixAddict's Avatar
SixAddict
If I recall I was able to use hardware off wheel liner and then add these as needed.
Old Apr 2, 2021 | 07:22 PM
SixAddict's Avatar
SixAddict
If you expand photo you can see the two screws I added. But again these were C7 Carbons fiberglass side skirts I think EOS are different.
Old Apr 3, 2021 | 10:44 AM
tommyc6z06's Avatar
tommyc6z06
2023 Corvette of the Year Finalist - Unmodified
2022 C6 of the Year Winner - Unmodified
Interesting...I just got my cheapo ABS EOS skirts and have the screws/hardware kit but no double sided tape. I’ll only get around to installing in a few weeks, but it appears I’ll have to get more screws too.
I’ll also be putting protective film over the tops of the skirts to avoid scuffs as well as on the wheel well spats. The ABS looks cheap enough to shatter if a small stone or pebble gets kicked up
Old Apr 3, 2021 | 11:55 AM
corvettejoe09's Avatar
corvettejoe09
My ZR1 came from the factory with aluminum pop rivets.
I replaced my side skirts about 2 years ago.
Drilled out the soft rivets (easy) & installed new aluminum ones.
Rexka 30pcs Bumper Cover License Frame Wheel Flare Fender Split-Type Rivets Compatible with GM 11516807 Buick Cadillac Chevrolet GMC Hummer PontiacRexka 30pcs Bumper Cover License Frame Wh…
$16.99$16.99
I hope this helps.
Joe
Old Apr 3, 2021 | 12:02 PM
corvettejoe09
To answer your 2nd question:
Fastening splash guards to the side skirts, as it came from the factory-
aluminum pop rivets also.
Old Apr 4, 2021 | 10:58 PM
Function Racer's Avatar
Function Racer
I used self tapping screws as well, but used rubber washers in between the skirt and body so no rubbing/ movement occurred. Almost 3 years, still zero issues. Best of luck!
Old Apr 4, 2021 | 11:24 PM
astepup's Avatar
astepup
I hadn't thought of the ABS possibly cracking from the underside due to rock impacts. I'm going to attach mine in a couple of weeks but now I'm thinking it can't hurt to either coat the bottom of them with some kind of epoxy or maybe even a couple of layers of Gorilla Tape. I'm still debating on using the supplied screws or going with rivets.
Old Apr 4, 2021 | 11:43 PM
tommyc6z06's Avatar
tommyc6z06
Hmm...maybe I’ll put some Gorilla tape underneath. Good idea.
I’m also debating whether or not to use rivets instead.
GM did...
Either way, it’s kinda unappealing to me to drill holes into the rockers 😬
To EOS zr1 side skirts missing hardware
