Trunk release
The button on the dash, the button on the fob, the button above the rear license plate and the metal key in the rear keyhole..
Which one of these methods do not not work? Or is it that none of these work?
https://www.corvetteforum.com/forums...tch-issue.html
Good luck.
GD
Check this before you start buying parts for the latch.
Circuit/System Description
The body control module (BCM) grounds the trunk release control signal circuit based on trunk release switch signals from either the interior rear compartment lid release switch or the exterior rear compartment lid release switch. The rear compartment lid pull down actuator is supplied battery voltage at all times via the TRUNK RELEASE fuse. When either the interior or exterior rear compartment lid release switch is pressed, the trunk release switch signal circuit is grounded. This input will request the BCM to momentarily ground the trunk release control signal circuit, which will open the rear compartment lid.
Circuit/System Testing
Trunk Release Inoperative from Interior Switch
Ignition OFF, disconnect the harness connector at the interior rear compartment lid release switch.
Test for less than 1.0 ohm of resistance between the ground circuit terminal A and ground.
⇒ If greater than the specified range, test the ground circuit for an open/high resistance.
Ignition ON, verify the scan tool trunk release switch parameter is INACTIVE.
⇒ If not the specified value, test the signal circuit terminal D for a short to ground. If the circuit tests normal, replace the BCM.
Install a 3-A fused jumper wire between the signal circuit terminal D and ground. Verify the scan tool Trunk Release Switch parameter is ACTIVE.
⇒ If not the specified value, test the signal circuit for a short to voltage or an open/high resistance. If the circuit tests normal, replace the BCM.
If all circuits test normal, test or replace the interior rear compartment lid release switch.
Trunk Release Inoperative from Exterior Switch
Ignition OFF, disconnect the harness connector at the exterior rear compartment lid release switch.
Ignition ON, verify the scan tool Exterior Rear Compartment Lid Release Switch parameter is INACTIVE.
⇒ If not the specified value, test the signal circuit terminal B for a short to ground. If the circuit tests normal, replace the remote control door lock receiver (RCDLR).
Install a 3-A fused jumper wire between the signal circuit terminal B and ground. Verify the scan tool Exterior Rear Compartment Lid Release Switch parameter is ACTIVE.
⇒ If not the specified value, test the signal circuit for a short to voltage or an open/high resistance. If the circuit tests normal, replace the remote control door lock receiver (RCDLR).
If all circuits test normal, test or replace the exterior rear compartment lid release switch.
Trunk Release Inoperative from Key Switch
Ignition OFF, disconnect the harness connector at the rear compartment lid pull down actuator.
Test for less than 1.0 ohm of resistance between the ground circuit terminal F and ground.
Ignition ON, verify the scan tool Trunk Key Cylinder Switch parameter is INACTIVE.
⇒ If not the specified value, test the signal circuit terminal E for a short to ground. If the circuit tests normal, replace the BCM.
Install a 3-A fused jumper wire between the signal circuit terminal E and ground. Verify the scan tool trunk key cylinder switch parameter is ACTIVE.
If all circuits test normal, test or replace the rear compartment lid pull down actuator.
Trunk Release Inoperative from All Switches
Ignition ON, verify that a test lamp illuminates between the B+ circuit terminal H and ground.
⇒ If the test lamp does not illuminate, test the B+ circuit for a short to ground or an open/high resistance. If the circuit tests normal and the B+ circuit fuse is open, test or replace the rear compartment lid pull down actuator.
Connect a test lamp between the control circuit terminal B and the B+ circuit terminal H.
Command the trunk release ON and OFF with a scan tool. The test lamp should turn ON and OFF when changing between the commanded states.
⇒ If the test lamp is always ON, test the control circuit for a short to ground. If the circuit tests normal, replace the BCM.
⇒ If the test lamp is always OFF, test the control circuit for a short to voltage or an open/high resistance. If the circuit tests normal, replace the BCM.
I have a C6Z06 2008 and I took the rear trunk release button out and cleaned it, I think I used silicone grease once cleaned, and put it back in years ago. It went from dead to perfect and works perfect now. I honestly can't remember if I could use the FOB and it worked fine or not, I think it was just the rear button didn't work, but somehow I knew it was the button on the rear of the car that was bad and it worked thereafter. good luck. Start with fuse, then do mechanical, then do electrical troubleshoot.
Cleaning the pushbutton switch in the back is easy and also a good thing to do.
Anyone have the wiring diagram for a 2010 C6 MT Base for the rear hatch release circuit?
My rear button (above license plate) doesnt work. it's beeen replaced and when pushed I hear a relay somewhere clicking, but it does not open.
The release switch in the dash works fine.
So whatever relay I hear clicking may be bad, but regardless, I'm a EE so if I had the schematic, I could corner this easy.
Thanks!
Thanks!
Sent you a PM
