Auto not going into gear.
Old Apr 15, 2021 | 07:31 PM
Titan22's Avatar
Titan22
Default Auto not going into gear.
My wife’s 08 Z51 auto had the plastic clip fall apart on the transmission cables a couple years back so I replaced with aftermarket ones. Just somewhat recently on occasion the car won’t shift. The most recent after a short run stopped at a gas station and it wouldn’t come out of park, I did a little rocking of the car and shifted as it should. I’ve noticed on other auto cars they have an over ride on the console if the break pedal doesn’t activate to allow the trans to shift but I didn’t see one here. Any thoughts on what to check or watch for? I don’t think the cable has any adjustment?
thx
Old Apr 15, 2021 | 07:59 PM
gdmoore01's Avatar
gdmoore01
You may find your answer contained within this comprehensive thread. Be sure to select the referenced threads within, to gain as much information as you can on the subject.
https://www.corvetteforum.com/forums...use-found.html
Good luck.
GD
Old Apr 15, 2021 | 08:42 PM
4SUMERZ's Avatar
4SUMERZ
It's caused by a weakened microswitch that will not send the signal to the solenoid to release the shifter locking pawl. It's really a shame that GM decided not to put an override like other GM vehicles have.
Regardless, most on here with autos have just tied back the locking pawl, or ran a wire loop back to the console under the armrest to pull to release the locking pawl if needed.
I'm sure that this is in the link provided, but if not, PM me your e-mail address and I can send you the info in PDF format.
Old Apr 16, 2021 | 05:09 PM
klangstone's Avatar
klangstone
https://www.corvetteforum.com/forums...post1603302182
To Auto not going into gear.
