C6 new bcm
So firmware flash the BCM with Tis2000 or TDS to firmware set up/ learn/ hand shake it with the cars systems security code to start with.
Hence replace and flash as your firmware flash method for Tis2000 or TDS.
Next, using Tech II, go into BCM special programing, make sure BCM set to USA if you are using the car in the USA, then take a look at the RPOs/options list to make sure what is installed in the car, is selected in the list, and what is not in the car, is not selected on the list. Granted that the video is more about turning F55 /RTD off, will still go through the list to double check that what is in the car, is selected on the list. Hence car may have not come with Hud or some other feature to start with,added in later, will not be selected from the Tis2000/TDS firmware flash alone off the vin number.
Just skip to 3:00
Just skip to 3:00
https://youtu.be/5tJl8XQ6Dzo
