question regarding master cylinder install
Old Apr 29, 2021 | 12:04 PM
vetza12's Avatar
vetza12
Default question regarding master cylinder install
is this the full part ready for installation? or is it missing anything? $82 is a very good price if true. thnx . ACDelco 18M2535 Professional Durastop Brake Master Cylinder Assembly
Old Apr 29, 2021 | 12:22 PM
vetza12's Avatar
vetza12
also wondering if a bad/failing master cylinder would throw any codes on the c6? i have no issue with my brake pedal but noticed a slight leak on the cap and around the seams after a hard driving sesh.
Old May 4, 2021 | 04:02 PM
Lee Cromwell's Avatar
Lee Cromwell
Make sure to bleed the master cylinder before you install it
Old May 4, 2021 | 05:20 PM
gdmoore01's Avatar
gdmoore01
In answer to your question, yes this is the Brake Master Cylinder hydraulic pump and contains a reservoir that holds brake fluid. The only thing missing is brake fluid and installation.
GD
Old May 4, 2021 | 08:25 PM
Lag1791's Avatar
Lag1791
I just replaced mine. I bought the same one at RockAuto and think I paid $70.
You have to bench bleed it before installing it. I bought a bench bleed kit on Amazon for about $12. Very easy to replace and now I can see the brake fluid level.
To question regarding master cylinder install
