dash command q
Old May 3, 2021 | 06:42 PM
ry57pont's Avatar
ry57pont
Default dash command q
I just installed a dash command, 1st to get my boost PSI readings. I have a e-force installed and the dyno sheets say 9psi. When i select the MAP display i read 20 PSI on the DIC. no way that is correct. 2nd i wanted to see my shock damping percentage. I have the Jim Mero updated ride control and cant really feel the difference between the two settings. I was hopeful that the dash command would give me the percentage readout of the shock dampening so I could visibly see the difference. but while driving i only get 0% displayed on all four shocks. any ideas?
this is on a 2011 GS
