Help!
Old May 8, 2021 | 02:22 PM
Pb82 Ronin's Avatar
Pb82 Ronin
Default Coil relocation plug wire part numbers
I found good part numbers for a universal spark plug wire kit that works for LS7 coil relocations. I'm mid process and the Toms kit has let me down with the wrong boots on BOTH ends.
What I found that works with Summit... If it helps anyone, the 3 part numbers from summit you'll need are:
MSD 33048
MSD 34023
ACC 170180-8
And SUM-900399 if you need crimpers.
All these make a universal kit.
