HUD problem
Old May 18, 2021 | 10:15 AM
redrckt97's Avatar
redrckt97
Default HUD problem
my HUD keeps quitting .. I can reset it by removing the fuse and then re-inserting it (fuse is good) and the HUD works until I shut the car off
and then it quits again upon restart. When I replace the fuse there is a noise under the dash like a motor is running (?). The car is on a
battery tender when not being driven. Any ideas?
Old May 18, 2021 | 04:10 PM
rbwinston's Avatar
rbwinston
Can I assume you tried disconnecting the battery then reconnecting to reset the computer?? Regardless of the battery being on the tender how old is it? You know how sensitive these things are to proper voltage!!!
