oil pump replacement cost ??
Old May 24, 2021 | 10:15 PM
newbC6's Avatar
newbC6
Default oil pump replacement cost ??
I was reading another thread where their pump went out. Got me thinking since I have a boosted LS2 with 108k miles, that I may be on borrowed time. Anyone know the average cost of hiring a mechanic to do a replacement? I know a lot of the cost would be varying by region but just a general idea. Also, if I go that route, would it be prudent to go ahead and replace the timing chain?
Old May 25, 2021 | 11:08 AM
helga203's Avatar
helga203
300 to 500 This is private, the other is stealership.
between $1,210 and $1,451
Chevrolet Corvette Oil Pump Replacement Cost Estimate. The average cost for a Chevrolet Corvette oil pump replacement is between $1,210 and $1,451. Labor costs are estimated between $923 and $1,164 while parts are priced at $287.
Old May 25, 2021 | 04:31 PM
Orion2011's Avatar
Orion2011
It's a lot of work. I changed mine out when I did my cam.
Old May 25, 2021 | 04:36 PM
Turbo6TA's Avatar
Turbo6TA
2021 C6 of the Year Finalist - Modified
Not cheap at all ! ... about the same price as replacing the harmonic balancer.
Old May 25, 2021 | 04:58 PM
ls1121's Avatar
ls1121
St. Jude Donor '14-'15
yes that's why I did all, so much work at one time.
Old May 25, 2021 | 05:20 PM
Turbo6TA's Avatar
Turbo6TA
And if your going to replace the oil pump, or even the harmonic balancer ... you might as well replace the camshaft too while your at it.
And if you are going to pay a shop to have this done ... the harmonic balancer change, or the oil pump change, or the camshaft charge should all be within a few dollars labor of each other.
Do um all at once !
Old May 25, 2021 | 05:34 PM
newbC6's Avatar
newbC6
The balancer was changed when the SC was added. Running an ATI. Not sure about changing out the camshaft since it has a supercharger. Was probably going to do just some wear items. pump, timing gear set, new serpentine belt.
Old May 25, 2021 | 05:37 PM
Turbo6TA's Avatar
Turbo6TA
Okie Dokie ...
To oil pump replacement cost ??
