Code
Old May 29, 2021 | 07:39 AM
Rachel Allison's Avatar
Rachel Allison
6th Gear
Default Code
I have a puzzler for everyone. My 2011 base is intermittently throwing a code P219A. Have any of you guys had this code, and what was the ultimate fix?
Old May 29, 2021 | 08:45 AM
4SUMERZ's Avatar
4SUMERZ
According to others that have received this same code, it could be caused by a fuel trim imbalance from side to side, caused by a lazy O2 sensor. The sensor is not bad enough to cause a bad O2 sensor code. Check the wiring to the sensors before you start replacing parts. Some clear the code, and it goes away.
https://www.corvetteforum.com/forums...2-sensors.html
