Shift problem
Old Jun 11, 2021 | 07:57 AM
flby55's Avatar
flby55
Default Shift problem
The problem I have that at times when the car is started it will not shift out of park no matter what I do but if I shut the car down and restart the car it is ok sometimes it takes 2/3 times of restarting the car. This does not happen all the time sometimes it will go weeks in between it happening. Any idea what could be causing this problem as it seems it could almost be an electronic problem but who knows. Any ideas about this? TIA
Old Jun 11, 2021 | 10:01 AM
jimobo60's Avatar
jimobo60
Default Shifter sticks in Park
See related thread below.
Old Jun 11, 2021 | 10:06 AM
HK770's Avatar
HK770
https://www.corvetteforum.com/forums...use-found.html
Both A4 and A6 shifters show this problem. As a work around this can be done or just wire it back.
Old Jun 11, 2021 | 10:16 AM
nplenzick's Avatar
nplenzick
Common problem as it happened to me with my 09. The video above explains it all.
Old Jun 11, 2021 | 10:34 AM
flby55's Avatar
flby55
Wow thanks for the info no way I will attempt that fix but at least I know what the problem is and hope the person that does work on my 2009 vette has done this before!
Old Jun 11, 2021 | 10:40 AM
nplenzick's Avatar
nplenzick
its not as bad as it looks. The biggest problem I had was getting some of electrical connections off of the switches. However if your not that mechanicaly inclined let someone who is do it.
Old Jun 11, 2021 | 10:42 AM
Squeaky Wheel's Avatar
Squeaky Wheel
I’ve encountered the exact same issue. Haven’t corrected the problem yet, but looks like an easy issue to fix once you remove the center console. There in lies the problem. The videos I’ve watched give a pretty good summation of how to do that, but they are all of C6’s with a manual shift ****, which is easy to remove to then pull the leather boot up and out of the way. I’m told the boot does not have to be pulled up over the shift **** to allow access the locking pawl, (which I plan to “modify” ), but still question if there will be enough room to get at it.
There are several u tube videos on ways to modify that plastic locking pawl. Some snip it off so it’ll never be an issue again. Others attach a thin wire or fishing line around it and route that into the area under the armrest with a small ring to pull to release it. Or you can replace the solenoid that activates the pawl to release, but that solenoid may eventually go bad again. The other 2 options seem to me like a better solution.
Old Jun 11, 2021 | 11:35 AM
2008 Corvette's Avatar
2008 Corvette
2020 C6 of the Year Finalist - Modified
Default Shifter
WTF. You state a M6 shift ****. M6’s do not have this problem.
Old Jun 11, 2021 | 11:42 AM
Squeaky Wheel
No, you misunderstood. Mine’s an automatic, same as the OP’s, and is encountering his same problem. All the videos I’ve watched for removing the console involve M6’s. Sorry for the confusion.
Old Jun 11, 2021 | 12:34 PM
2008 Corvette
So you have the same problem but have never done the cure ? If you don’t have the answer why reply.
Old Jun 11, 2021 | 02:47 PM
Squeaky Wheel
Man, what gives with you? You trying to provoke or something? I simply pointed out to the OP that I, as apparently many others, have the same problem, and did point out that there was a cure. To either clip off the pawl, tie a wire release line around it and route that line into the storage area under the armrest, or replace the pawl activation solenoid. That was the answer.
The problem is getting the console on the A6 removed to access the area, or more specifically, getting the shifter boot over the shift ****. Easy on an M6, but haven’t found a video showing how to do that on an A6 and am hesitant to start tearing into it until I see how. Or if that’s even necessary. May just take it to a dealer and be done with it.
Old Jun 11, 2021 | 05:11 PM
4SUMERZ's Avatar
4SUMERZ
The shifter boot just needs to be lifted up to the bottom of the shifter ****. There is lot's of room to get at the locking pawl, and all the micro switches.
Old Jun 11, 2021 | 05:20 PM
Squeaky Wheel
Thanks 4SUMERZ. That’s reassuring, and I appreciate your chiming in. Knowing that, I may try to tackle the project on my own. It’s just been intermittent and I’ve put it off, opting to live with the aggravation. But I know I really should fix it.
Old Jun 11, 2021 | 08:17 PM
nplenzick's Avatar
nplenzick
I have no idea how you can get the shifter boot up without destroying it and not taking the counsel out. Mine was a delicate procedure and looking at it now i just can't see how I could have accomplished it otherwise.
Old Jun 12, 2021 | 03:43 PM
Dutch08's Avatar
Dutch08
I had the problem on my 2008. I don't recommend this fix and you might get stranded since it doesn't fix the problem, at least sort of.
Take a spray can of dry Teflon lube, spray all around using the long nozzle extension to get under the boot. (I did take the console off to do mine, but I THINK it would work just by pulling the boot down and using the nozzle to spray all the parts under the boot.
This fix worked for me for 2+ years until I sold the car.
To Shift problem
