Tpms?
Old Jul 7, 2021 | 08:42 PM
USA1LBvert's Avatar
USA1LBvert
Default Tpms?
Have a 2006 Base convertible and still had the original Goodyear runflats. So after recommendations from this forum I bought continental extreme contacts non-runflat. Wow is all I can say. The ride difference is night and day. Never runflats again. Also installed new z06 replica wheels so I changed out the tpms. A friend of mine with a shop mounted and balanced wheels and tires. I bought the tpms reset tool. Vxda el-50448. The tire pressure on the dash still reads the old pressure of 28-30lbs. The new tires are 51lbs. I tried the procedure like 15 times. Car in accessory mode,hold lock and unlock til I hear the beep than use the reset tool. But I never get the beep that tells me it read the new tpms and the pressure in the car still reads 28-30lbs. Any ideas?thanks
Old Jul 7, 2021 | 08:47 PM
USA1LBvert's Avatar
USA1LBvert
Tpms were Schrader 20076 that were installed. Thanks
Old Jul 7, 2021 | 09:45 PM
rbwinston's Avatar
rbwinston
Just had the same tires and same Schrader's installed and Discount tire couldn't get the car into re-learn mode. Wound up taking it to a dealer who I think used a Tech-2 to get them to read. By the way, love the tires too!
Old Jul 7, 2021 | 10:16 PM
USA1LBvert's Avatar
USA1LBvert
Thanks. I was gonna take to the dealer for oil. I will have them do that also. I still need an alignment. When I took the front driver side tire off, the inside tread was completely worn right down to the belt. Honestly with these new tires I feel like I’m driving a different car. I can’t say it enough how much better the ride and handling is!!
Old Jul 7, 2021 | 11:19 PM
Chatman's Avatar
Chatman
Just a reminder that you can do the learn process before installation to make sure that all will work. You will get 0 pressure readings of course but you will know that your tpms will sync with the car.
Old Jul 8, 2021 | 12:39 AM
FatsWaller's Avatar
FatsWaller
First, can you explain the bit about the new tires being at 51 lbs?
Second, if you are driving around and nowhere near the old wheels and sensors and if the new sensors aren't programmed, you should be seeing 'xx' as the pressure. What you are describing doesn't make sense, no offence intended.
Old Jul 8, 2021 | 07:43 AM
USA1LBvert's Avatar
USA1LBvert
No offense taken. The new continentals take 51psi max pressure and that’s what I have in them. I’ve had the car out a couple times and I am getting no xx sign for the tires. I don’t know why but it shows the old tire pressure. Makes no sense to me. I’m getting conflicting information about psi. I see people running 38psi to 50psi cold. Kinda lost with this.
Old Jul 8, 2021 | 08:13 AM
1bdvet's Avatar
1bdvet
U.S. Air Force
St. Jude Donor '05 thru '26
Look at your drivers door jam, it will say nothing about tires set to above 30 PSI, with that pressure it should be hard drive, and they will adjust it when you get wheel alignment other wise, it won't be set right.
Hope they installed correct part.
Lower your pressure just because the tires says it, you're not ride it at that pressure!
Old Jul 8, 2021 | 08:17 AM
dmk0210's Avatar
dmk0210
I have the same tires. Run them at 30 PSI. Yours are grossly overinflated.
Your tire pressure is set based on the car, not the tire. Inside the driver's door jamb is a placard that shows the proper pressure.
Old Jul 8, 2021 | 08:59 AM
sramzzz's Avatar
sramzzz
I recently got new Schrader 20076 sensors and the same reset tool you bought. Once in relearn mode you have to receive a beep at each sensor and a double beep on the last one or it is not working. Make sure that you point the reset tool just above the rim and at a angle and it should read. I read somewhere that the reset tool does not work if you have it placed on the rim itself. Guess I was lucky as it worked the first time for me. Also leave the door open once you have it in learn mode. I think shutting it will make the car go to sleep and that might be why nothing is working.
Old Jul 8, 2021 | 09:07 AM
FatsWaller's Avatar
FatsWaller
When the car is moving, tire pressure data is gathered about every 30 seconds. This is what I observe on my vette. If the car can't get a reading from one or more of the sensors it will throw up an error message on the DIC and a yellow light shaped like a tire will show up on the instrument cluster. If you scroll through the readings on the DIC, the sensors that can't be read will display xx for the pressure. I've seen this numerous times, as have others. That's the way the system operates. If the sensors in your car haven't been programmed, then by definition, they can't be read. The fact that your system continues to display the old values suggests a problem that needs to be investigated.
About the tire pressure, you are not the first to be tricked into thinking that the max pressure is what to use. As stated, it's 30 psi cold. If your TPMS system was working correctly, you would have received an overpressure warning on the DIC, which I believe is triggered at 40 psi give or take. I had this happen once when the shop overfilled 1 new tire.
Old Jul 8, 2021 | 09:08 AM
unkled20's Avatar
unkled20
This, with every car. Inflate the tires to what the car says, not the max for the tires.
Old Jul 8, 2021 | 11:26 AM
USA1LBvert's Avatar
USA1LBvert
Ok thanks everyone. I will bring the pressure down to specs in the door jamb. As far as the dash I am getting no xx or anything else. For shiots and giggles I lowered the pressure in one of the wheels I took off and the low tire pressure light came on in the car. The car and old wheels are in the same garage. Maybe I should drive the car out somewhere in the open and try? As far as tire pressure I always thought that the psi on the tire was the correct psi to fill the tire. All these years I had it wrong! Lol.
Old Jul 8, 2021 | 11:38 AM
sramzzz's Avatar
sramzzz
it should not matter that those other wheels are close by. Make sure you have a new battery in the reset tool. When I did mine I held the tool at an angle on the tire as in pic below and it worked great. If you don’t get a signal on the left front there is no need to move on since that one needs to be done first. Could be a bad sensor or the tool is not working.
Old Jul 8, 2021 | 11:41 AM
FatsWaller's Avatar
FatsWaller
That explains it. You car is getting the readings from the old sensors. Drive somewhere not close to your garage.
Old Jul 8, 2021 | 12:01 PM
sd45t2's Avatar
sd45t2
You are probably getting excellent gas mileage!!
Old Jul 8, 2021 | 12:15 PM
D-Dub2013's Avatar
D-Dub2013
Your friend that mounted and balanced them should know they should not be at 51lbs. Way to high. Probably should just go to a decent tire shop.
To Tpms?
Old Jul 8, 2021 | 12:39 PM
USA1LBvert's Avatar
USA1LBvert
Ok so I drove the car away from the house. No difference. Car is still reading the old tires ,and still giving low tire pressure from the wheel that is no longer on the car. Tool was brand new and brand new Duracell battery for it. Also tpms brand new from rock auto with current dates on them. Lowered all tires down to 30lbs. Crazy
Old Jul 8, 2021 | 01:05 PM
1bdvet's Avatar
1bdvet
U.S. Air Force
It might be the wrong TPMS sensors they sold you, might make difference with the correct ones.
Here is a video:
Old Jul 8, 2021 | 01:25 PM
FatsWaller's Avatar
FatsWaller
Drive it for 20 minutes or so, and nowhere near your house. The reach of the sensors is not that far, but I'm not sure how far away you need to be. Sooner or later the car will poll the sensors and won't be able find them since they are in the garage. I would have thought 10' would do it. There's no doubt that it was reading from the old sensors because the low pressure warning clearly came from one of them.
If it makes you feel any better, the brand new tpms tool I got from Amazon didn't work either, with a brand new battery. Dealer reset them for me for free. Also, there's some evidence that a tune might interfere with programming the sensors. Does your car have a tune?
