Possible Coolant Temp Sensor issue
As soon as I clear it, the temp display on my dash starts working and matches what's the temp on the Holley display.
I switched from a FAST 102 to an MSD and that’s when it started happening. The tune was tweaked and is spot on for the Holley ecu.
I’m thinking the sensor is bad and needs to be replaced or the code just needs turned off? It’s not a huge deal since the Holley read out in accurate, it’s just annoying seeing it on the DIC.
Circuit/System Description
The engine coolant temperature (ECT) sensor is a variable resistor that measures the temperature of the engine coolant. The engine control module (ECM) supplies 5 volts to the ECT signal circuit and supplies a ground to the low reference circuit.
The ECM uses this high side coolant rationality diagnostic to determine if the input from the ECT sensor is skewed warmer than normal. The internal clock of the ECM will record the amount of time the ignition is OFF. If the calibrated ignition OFF time is met at start-up, the ECM will compare the temperature difference between the ECT and the intake air temperature (IAT), to determine if the temperatures are within an acceptable operating range of each other.
Conditions for Running the DTC
• DTCs P0112, P0113, P0117, P0118, P0502, P0503, P0601, P0603, P062F, P2610 are not set.
• The vehicle has had a minimum ignition OFF time of 10 hours.
• The ignition is ON.
• The start-up IAT is more than -7°C (+19°F)
• The Fuel Level Sensor parameter is more than 5 percent.
• This DTC runs once per ignition cycle within the enabling conditions.
Conditions for Setting the DTC
• The ECM detects a temperature difference at power-up that indicates that the ECT sensor is 30°C (54°F) more than the IAT sensor.
OR
• The ECM detects a temperature difference at power-up that indicates that the ECT sensor is 10°C (18°F) more than the IAT sensor, and the time spent cranking the engine is more than 10 seconds, when the fuel level is more than 5 percent.
OR
• With the power-up IAT more than -7°C (+19°F), the ECM detects a temperature difference at power-up that indicates that the ECT sensor is 20°C (36°F) more than the IAT sensor. Then the vehicle must be driven for more than 6 minutes and 40 seconds at more than 40 km/h (25 mph). If the IAT sensor then decreases more than 4°C (7°F), an engine block heater was detected and the test is aborted. If the IAT sensor does not decrease, an engine block heater was not detected and DTC P0116 will set.
Circuit/System Verification
If the ignition has been OFF for 8 hours or more, the ECT and the IAT, should be within 6°C (11°F) of each other and also the ambient temperature. Turn ON the ignition, with the engine OFF, and use a scan tool to observe the IAT and the ECT sensor parameters. Compare those sensor parameters to each other and also to the ambient temperature. A slight to moderate resistance in the IAT signal or low reference circuit, can widen the spread between the two sensors and cause this DTC to set.
An IAT sensor that is skewed lower at various ambient temperatures, due to more resistance than is normal, can widen the spread between the two sensors and cause this DTC to set. Measure and record the resistance of the IAT sensor at various ambient temperatures, and then compare those measurements to the Temperature vs Resistance Table. Refer to Temperature Versus Resistance .
Inspect the ECT sensor terminals for corrosion, and for engine coolant leaking through the sensor.
Caution: Under pressure, the temperature of the solution in the radiator can be considerably higher, without boiling. Removing the radiator cap while the engine is hot (pressure is high), will cause the solution to boil instantaneously, with explosive force. The solution will spew out over the engine, fenders, and the person removing the cap. Serious bodily injury may result. Flammable antifreeze, such as alcohol, is not recommended for use at any time. Flammable antifreeze could cause a serious fire.
Turn OFF the ignition.
Inspect the cooling system surge tank for the proper engine coolant level. Refer to Cooling System Leak Testing and Cooling System Draining and Filling .
Circuit/System Testing
Important: All electrical components and accessories must be turned OFF and allowed to power down.
Ignition OFF, disconnect the ECT harness connector at the ECT sensor.
Ignition OFF, test for less than 5 ohms of resistance between the low reference circuit and ground.
⇒ If greater than the specified range, test the low reference circuit for an open/high resistance. If the circuit tests normal, replace the ECM.
Ignition ON, verify the scan tool ECT Sensor parameter is less than -39°C (-38°F).
⇒ If greater than the specified range, test the signal circuit for a short to ground. If the circuit tests normal, replace the ECM.
Install a 3A fused jumper wire between the signal circuit and the low reference circuit. Verify the scan tool ECT Sensor parameter is greater than 149°C (300°F).
⇒ If less than the specified range, test the signal circuit for a short to voltage or an open/high resistance. If the circuit tests normal, replace the ECM.
If all circuits test normal, test or replace the ECT sensor.
Do I need to have an IAT sensor plugged in to the stock ecu for reference?
wondering if maybe you figured this out. Thank you!
