Speaker upgrade
Hence 3.5" in the doors, and 5.25"s in the rear.
The speakers are poly cone, and come with build in tweeters to get crisper highs, as well pick up some more mid base fill in the rears from the CS speakers as well.
https://www.kicker.com/cs-series
Now on the bose amp, the only two speakers out of the system that are stereo channel, are the two 3.5" in the doors.
The 3.5 in the dash, thumpers in the doors, as well as the 5.25" in the rears, are all mono channel out of the Bose amp (for filler).
So since the dash speaker is only a fill speaker, can leave the OEM in play, or disconnect the dash speaker to get better side to side separation out of the doors speakers.
You could go with other speakers, but as stated, would lose the needed sensitive to work correctly with the OEM thumpers in the doors correctly.
Note, the Kicker KS can handle more power from another amp putting out more power, but will be a step backwards when used with the Bose amp since they have lower sensitivity.
