I have a base auto 2012 and I'm removing the Kooks headers and mid-pipe. The mufflers will not be removed. How high will I need to get it jacked up and will the header bolts work to install the factory manifolds? I think I have everything else that I need. Any tips from some of you that have done this are appreciated. Thanks
You will want to get the front as high in the air as your jack and jack stands will allow. Higher the better. Same header bolts should work for the stock manifolds.
