2005 HUD Issue
Wouldn't call it "butchering"....the one cut is reattached with aluminum HVAC sealing tape. This tape can hold 20-pound ductwork pieces together in a hot attic, so I think it is also effective in holding a 6-ounce plastic duct together inside the dash. (all weights are estimates, and are coming from a dumass)
Ignition OFF, disconnect the harness connector at the HUD.
Test for less than 1.0 ohm of resistance between the HUD ground circuit terminal 6 and ground.
⇒ If greater than 1.0 ohm, test the HUD ground circuit terminal 6 for an open/high resistance.
Verify a test lamp illuminates when connected between the HUD battery positive voltage circuit terminal 1 and the ground circuit terminal 6.
⇒ If the test light does not illuminate, test the HUD battery positive voltage circuit for an open/high resistance.
Verify a test lamp illuminates when connected between the HUD dimming up switch signal circuit terminal 11 and B+ while pressing the HUD dimming up switch.
⇒ If the test light does not illuminate, test the HUD dimming up switch signal circuit for a short to voltage or an open/high resistance. If the circuit test normal, replace the HUD.
Verify a test lamp illuminates when connected between the HUD dimming down switch signal circuit terminal 12 and B+ while pressing the HUD dimming down switch.
⇒ If the test light does not illuminate, test the HUD dimming down switch signal circuit for a short to voltage or an open/high resistance. If the circuit test normal, replace the HUD.
If all circuits test normal, test or replace the HUD switch.
If you decide to replace the unit, here is part of my write-up that has some tips.....like cut the duct far enough over to get your hand in there. Looking at the thread date, looks like I have had my HUD almost 12 years now. No issues with HUD of the duct that I cut:
1) Pull dash surround bezel by prying on both bottom corners (below right start button and left a/c vent) with a scratch-free tool. Once those areas pop out, you can work your fingers around, popping off the bezel. TIP: may have to lift top of dash slightly to remove and re-install this piece AND the instument cluster. Remove the dimmer, DIC, start and sensor plugs during removal. Remove the left pod dummy piece and install the new HUD switch.
2) With a 7mm nutdriver, remove the 4 cluster screws and the 1 left a/c vent retaining screw. Pull the cluster out, disconnecting the gray and black plugs.
3) Using a hacksaw that is an open blade on one end with a handle on the other, carefully cut the large duct on the right side. TIP: Don't just cut it wide enough to get the projector in - you need some room to get your hand in to tighten the right nut. You will want to cut it fairly close to the sensor that is screwed into the duct.
4) Once the duct is cut completely through, pull on it to yank it out which will break off the mounting tab on the left side. You can now remove the filler bezel on top of the dash and replace it with the HUD bezel. TIP: This is done by pushing the panel forward (toward the windshield) and pulling it up and out of the slots.
5) Fit projector into dash working it onto the 2 studs. I cut a notch in the left mounting ear so the projector can be dropped over the right stud and then swung over onto the left stud without having to lift it over the stud. Might try this if clearance is tight. To secue the back of the projector, get a J-nut or Speednut with screw and washer. A J-nut might slide over the leg of the projector but since there is a channel inside the leg you can just hold it in position while starting the screw. The rectangular speednut will not spin while tightening the screw (with a stubby screwdriver) because it is caught inside the channel of the leg. Install 2 6mm nylon locknuts with flatwashers on the studs. Hard to get to but can be done. TIP: use a 10mm ratcheting box end wrench since it is tight in there.
6) Reinstall a/c duct. I recommend aluminum HVAC tape over duct tape. TIP: first place a piece or two of tape on the top of the duct before inserting the cut-off section as it is hard to work tape around the top after installing it. Make sure tape is worked all the way around. Reinstall screw at left vent.
-- if you are having the HUD installed then cut the duct. You want this repair/replace done quickly, and at the lowest expense. Result ~99% factory look, feel, and reliability.
-- if you are doing it yourself then remove the dash. (Labor cost is $0 to It is far easier to remove/install the Hud and ensure all is tightened/installed correctly.) The result is 100% factory look, feel, and reliability. Plus you can replace bulbs, a bad speaker, etc. while you are in there. Warning! It is a huge amount of labor and assumes you have some experience (Nothing technical just general r&r).
My cut-the duct install has been nothing but 100% factory look, feel, and reliability for 12 years running. And that is with my homemade harness. Those who have done several HUD installs (complete....not just replacing the projector) have gotten the job down to less than 2 hours.
I followed the instructions here http://www.kawal.net/Dash%20Replacement.htm
I’ve removed the HUD in 2 C6’s, one by the cut the duct method and the other when I removed the dash. I prefer to remove the dash.
